Hi. Goto
www.kitchenaid.com and do a search for your model#. Look for the manuals tab, locate and download the parts list for your mixer. These drawings will assist you with disassembly and reassembly. Remove the Planetary assembly by driving out the single pin that holds it to the mainshaft. Clean and regrease it too.
Over time the grease in your mixer will begin to separate into oil and harder grease base. It's time to remove as much of the oil and grease as possible, and then regrease.
To extend the life of your grease, run your mixer for a few minutes every week to keep the oil suspended in the grease. If not used for a long time, the oil will seprate.
I recommend using Chevron FM ALC EP-2 food grade grease, and after 5 years or so when it begins to drip, if you get a few drops in your bowl it won't matter much, in comparison with a petroleum grease that you shouldn't eat at any time.
Goto
www.mendingshed.com and find their free Kitchenaid Service Manual and download it. This manual covers your mixer.
Regreasing your mixer isn't difficult, it is however, very messy to clean and regrease, so keep plenty of paper towels, rags, etc. handy. Latex or rubber gloves will help.
If this solution has assisted you, please rate it. Good luck! ricardok45
I was trying to clean mine and did the same thing. The manual refers to the brushes as being marked "right", "left", and "up". The only markings on the brushes are a part number. My mixer is 25 years old and was still going strong until I tried to clean it. Maybe the gunk was holding it together.
