Question about Vector 1 Million Power Series Spotlight & Air Inflator
Where can I get a replacement battery for a Vector VEC127Y spotlite??
  • 3 Answers
I just bought two for my VEC280 at www.batterymart.com at very reasonable price.
Posted on Oct 20, 2010
What tip polarity do I use to connect an after market charger?
The short answer is "The tip should be set to positive (+).
I found an old Vector VEC127Y Spotlight. It appeared to be in perfect condition but the battery was dead and there was no charger. I was able to buy a replacement battery at BatteriesPlus for $21 USD. Here is the link for the battery
REPLACEMENT VECTOR VEC127Y BATTERY
I also purchased a Universal A/C adapter to use as a charger at BatteriesPlus for $17 USD. Their site does not list it yet but here is the manufacturers link. Please note the original battery was rated 6Ah. The replacement is only rated for 5Ah. Which means one less Amp hour (Ah). Which means a shorter run time, after charging, than the original battery had. Otherwise they are equal.
UNIVERSAL AC ADAPTER
I installed the new battery. I set the AC Adapter to 6V and installed the largest of the seven adapter tips that came with the charger, with TIP set to be positive (+). I opened the battery compartment of the spotlight and disconnected both the red (positive +) and black (negative -) battery leads from the battery. I then plugged the adapter tip of the Universal AC Adapter into the spotlight and plugged the AC Adapter plug to a power outlet. With a multimeter I tested the polarity of the spotlight battery leads while charging. I was able to confirm that the Adapter TIP should be set to positive (+). After reconnecting the spotlight battery leads and setting the AC Adapter to charge, I have a perfectly great spotlight in full working order.
Dec 02, 2010 | Vector Spotlight - 1 Million Candles...
What volt and amp charger does the vec127y use
It uses a Class 2 Transformer to charge the battery. The input is 120V AC 60Hz 9W. Output is 12VDC 300Ma.
Nov 09, 2010 | Vector Spotlight - 1 Million Candles...
How do I change the light bulb in my Vector ACV 127Y?
Remove the black rubber ring from the face then unscrew the reflector. The replacement bulb is the same that goes in most common driving and fog light and may be purchased at most auto parts and Wal Mart stores.
Aug 03, 2010 | Vector Spotlight - 1 Million Candles...
The small flashlight on the handle will not turn off. When I press the button it goes off and then when i release it comes back on- can you assist?
It sounds like your switch is defective, unfortunately Vector lights are Non-Servicable except for replacement bulbs, batteries and chargers, so I don't think it is worth fixing.
Mar 19, 2010 | Vector Spotlight - 1 Million Candles...
Vector Super Sport Spot VEC127Y replacement battery
I need a new power supply for my Vector Spotlight, Model VEC127Y. Any suggestions as to where one can be purchased?
John seadoc@aol.com
Nov 03, 2008 | Vector 2M Pwr Rch Spotlight
Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
  • HIGH CANDLE POWER QUARTZ HALOGEN BULB DELIVERS A BRIGHT AND TIGHT BEAM
  • AREA WORKLIGHT IN HANDLE PROVIDES UP TO 15 HOURS OF LIGHT WHEN FULLY CHARGED
  • PROVIDES CONTINUOUS SPOTLIGHT USE FOR UP TO 25 MINUTES WHEN FULLY CHARGED
  • HIGH IMPACT, BREAK RESISTANT ABS AND POLYCARBONATE HOUSING
  • TOUGH, WEATHER RESISTANT AND BUILT FOR RUGGED OUTDOOR USE
  • REPLACEABLE 6 VOLT, 6 AMP HOUR, NON-SPILLABLE, SEALED BATTERY
  • LOCKING TRIGGER FOR ON/OFF LIGHT CONTROL
  • INCLUDES AC AND DC CHARGING ADAPTERS
  • INCLUDES BUILT IN HANDS FREE WORKSTAND
Sep 07, 2008 | Vector 2M Pwr Rch Spotlight
Vector 1 Million Power Series Spotlight & Air Inflator Logo
204 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Lawrence Oravetz
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
