A small sliding switch at the side of SD Card can be pushed in the lock position, did you check it ?A small sliding switch at the side of SD Card can be pushed in the lock position, did you check it ?
You can't post conmments that contain an email address.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
<p>Many times people
do not realize that a <span style="font-weight: bold;">SD card</span> can be <span style="font-weight: bold;">write protected </span>or locked. They
will <span style="font-weight: bold;">try to download pictures</span> or <span style="font-weight: bold;">make changes to the pictures </span>and the
<span style="font-weight: bold;">SD card will not allow</span> them to do it. The little lock feature on the
side of the card will <span style="font-weight: bold;">write protect the SD card</span> so that changes cannot
be made. You will need to <span style="font-weight: bold;">unlock the SD card</span> to be able to make the
changes that you want to make or download anything from it.<br />
<p><br />
<br />
<p><span style="font-weight: bold;">To allow the SD card
to be accessed</span> is a simple as sliding a small tab on the side of the
card to the <span style="font-weight: bold;">unlocked position</span>. Usually this means sliding the tab
towards the back of the card and away from the front of the card. The
card will have to be removed from the <span style="font-weight: bold;">camera</span> or <span style="font-weight: bold;">PC</span> to be able to do
this.<br />
<p><br />
<br />
<p>Here is a <span style="font-weight: bold;">picture
of an SD Card</span> and you can see the tab on the side of the card. It
clearly shows you what is the locked and unlocked positions on the
card.<br />
<p><br />
<br />
<p><img src="heatman101_2.jpg" /><br />
<br />
<p><br />
<br />
<p>This feature can
be very useful to make sure that you do not inadvertently <span style="font-weight: bold;">erase data
or pictures</span> from the card. If you have children viewing pictures on
the SD Card make sure to lock it before allowing them to play around
to make sure that they <span style="font-weight: bold;">do not erase your pictures</span>.<br />
<p><br />
<br />
<p>As you can see
this is a very good feature to have and it will be very useful to
you, but you do need to remember to unlock it before trying to make
changes to the card.<br />
Look closely at the memory card itself. There should be a tiny picture of a lock indicator on the card and a little tab to click or move to the lock position. There should also be a picture of an unlocked lock to signify which direction you need to move that little tab in order to unlock the memory card. Try sliding it to the unlock position to solve your issue.
Welcome to FixYa
Whats Showing when Trying to Open Pictures in Card.You can Open it by Putting card again to PC to view pictures.
If card is Damaged then you cant see it any more...
If card is LOCKED-It need to be Unlocked with Unlock device-then All data will be deleted..
I dont think it is locked....ONLY by just Removing from PC -card will not be Locked...
You can Open it manually...Let me know if you need further assistance...
Thanks for Connecting FixYa..
The SD card lock/unlock switch has been moved to the lock position. Remove the card and slide the switch (along the edge of the card) to unlock. If it is in unlock, try sliding the switch back and forth a couple of times. Reinsert the card and it should be ready to go.
Check to make sure you didn't accidentally move the locking switch on the SD card to the locked position. There will be a switch on the side of the card. One side of the switch says locked, (or has picture of a locked lock) and the other side says unlocked, or has a picture of an unlocked lock. Try it out.
Have you tired to unlock memory card unlock button ? SD cards do have write protection physical lock. take a look at this pic and unlock it, good luck!
