HP DeskJet F380 All-In-One Printer Logo
David M Posted on Sep 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer feeds blank pages.
When I print out existing documents (.doc, .xls, .txt, etc.) the printer feeds two blank pages, the print job that I requested, and another blank page.
Anonymous
Level 2:
Novelist:
  • Expert 144 Answers
  • Posted on Sep 23, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
144
Questions
Helped
50231
Points
359
Often in the Printer properties, there is a tickbox, to feed a blank sheet between print jobs. this is to assist in keeping print jobs seperated on busy printers.
Here is the way to change the setting on a single print job:
  1. Click the Start button
  2. Point to Settings
  3. Point to Printers (Windows 2000) or Printers and Faxes (Windows XP).
  4. Right-click the HP LaserJet driver you plan to use (2420)
  5. Click Properties .
  6. On the Advanced tab, uncheck Separator Page.
  7. Click OK to return to the Advanced tab.
  8. Click OK to save the settings.
Making the change a permanent thing For All print Jobs on this printer:
  1. Click the Start button.
  2. Point to Settings .
  4. Right-click the HP Printer you want to correct the settings to.
  6. On the Advanced tab, click Printing Defaults .
  7. Change any of the settings on the tabs. These settings become the defaults for the printer.
  8. Click OK to return to the Advanced tab.
  9. Click OK to save the settings and to close the printer driver.
5answers
Blank page feeding during print job
Please adjust paper size in printer properties.
2answers
Printing blank pages
MAKE SURE THAT ALONG WITH THE SOFTWARE YOU INSTALL THE PROPER DRIVERS
Spooling error
What make and model printer ?
There are a variety of reasons why a printer may feed a blank page through. This is, in some cases, an error. In other cases though it is a mistake in the page count or a simple matter of the printer trying to maintain itself.
Maintenance If a user has just loaded new paper into the printer or if an error message has recently been cleared the printer may run a blank page through.
Usually this is to make sure that the print path is now clear and that the next sheet it positioned correctly for printing.
Page Count
When a document is edited there is sometimes a blank sheet left at the end of the document. So, for example, if a 10 page document is edited down to nine pages, the computer and printer still sometimes read it as a 10-page document when a user hits the print key.
Page Separator
In some cases where a large number of documents are being printed, users may set a blank page separator.
This puts a blank page between copies of a document to show where one ends and the next begins.
A quick look at the printer's settings or control panel will tell you if this option has been turned on.
Fix a Printer Spool Error
When you send a job to your local or network printer, the print spooler is what keeps track of that job's location in the queue.
If the print spooler is not running, your job will not be able to reach the printer, so it is important to know how to resolve print spooler errors when they occur.
Click on the "Start" button and choose "Control Panel" from the menu.
Double-click the "Printers and Faxes" icon and locate your printer.
Double-click on the printer to get the list of jobs in the queue.
If you see any jobs in an error status, right-click on those jobs and choose "Cancel" from the menu.
Close the "Printers and Faxes" window and double-click on the "Administrative Tools" icon. Choose "Services" from the menu.
Scroll through the list until you see "Print Spooler," then right-click and choose "Start" from the drop-down list.
This restarts your print spooler and allow your jobs to print.
Right-click on "Print Spooler" again and choose "Properties" from the menu.
Go to the "Startup" option and set it to "Automatic."
This ensures that the print spooler starts each time your computer does.
Print spooler
http://social.technet.microsoft.com/Forums/en/itprovistaprinting/thread/cad5221a-d21b-4bf0-8e86-cacae254cb52
Feeds a blank sheet of paper after every print job
check and see if your cursor goes to the next page after your last written one in your document. If so then backspace to your last written page so that the blank page disappears because having this page the computer takes it as part of the document but because there is nothing on it a blank page comes out.
If I am not printing continuously, the printer does not print the first 5-6 printing jobs. When print job sent to the printer I get a blank page (printing job can be more than one page). After the blank...
It seems that " Print on both sides (Manually)" is selected in printing options., when you want to print any document Go to file Print > select printer and click properties and disable the Manual printing option in device settings.
You should be able to get printing without errors,
if the option is not checked then check for the default paper tray,
save the settings and reboot your laptop/desktop and restart printer as well so that settings should work properly and any given command gets clear from memory, If these all settings are ok, Uninstall the printer driver and download the latest version drivers from HP website and install see links below
hp LaserJet 1150/1300 printing system hp LaserJet 1150/1300 PCL5e driver
If you require more assistance feel free to reply to this post
Regards, BA
Printer not recognizing web browser print request
Hi scooter,
The solution to your problem is that need to go into control panel then printers and set printer as default. If that dont work then try to re-install your printer drivers that should do the job.
k24674
Grand Canyon Tech
Grand Canyon Tech
