Soyo SY-5SSM Motherboard Logo
Posted on Sep 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wondering where and what to type in autoexebat
Wondering where and what to type in autoexebat and configsys area to make computer look for cd driver. that seems to be the problem no dive D: or cd player is really recognized.
Anonymous
Level 3:
Genius:
  • Master 1,027 Answers
  • Posted on Sep 22, 2009
Anonymous
Master
Level 3:
Genius:
Answers
1027
Questions
0
Helped
380686
Points
2770
Those are old DOS commands, and depending on the OS version, is located in c:\windows\dos.
mscdex.exe is the driver that should be listed in config.sys.
like, DEVICE=C\windows\dos\mscdex.exe
When running Windows, the driver is re-loaded under it's own section, so the CD drive may be bad or the interface on the motherboard - if it shares the cable to the hard drive, then the interface is OK.
I've got a studio 1737 with dvd/cd rom driver CDEXK4LE3GHQZ01 SCSI cdRom Device TSSTcorpDVD+_RW TS-T633AATA Device. The driver no longer reads any dvd (film, game) but it reads audio cd without...
Hi!
Try this fix:
For windows XP: Click on start Click on run Then type Regedit HKEY_LOCAL_MACHINE> SYSTEM > CurrentControlSet > Control > Class > {4D36E965-E325-11CE-BFC1-08002BE10318}. In the right pane, if you have UpperFilters / LowerFilters, right-click UpperFilters / LowerFilters, then delete it. Exit registry editor Restart the computer
For Windows Vista / 7: Click on start Then type Regedit in the search box. HKEY_LOCAL_MACHINE> SYSTEM > CurrentControlSet > Control > Class > {4D36E965-E325-11CE-BFC1-08002BE10318}. In the right pane, if you have UpperFilters / LowerFilters, right-click UpperFilters / LowerFilters, then delete it. Exit registry editor Restart the computer
You can also check this link: DVD Drive Problem
Thanks!!
1helpful
MY PRINTER CANON MP 198 just now cant't connect to my computer ...and i also lost my cd to install ..so how can i do...urgent tq
Go to www.canon.com and in the search box type in your model number. Usually the drivers are located under the support area. After you enter your model you can type in driver.
Can't get webcam to work on messenger, it used to work, I must be doing something wrong do h I have to download a program
Reinstall you webcam drivers doing the following:
Unplug your webcam from your computer.
  1. Reboot your computer.
  2. Insert your webcam's manufacturer installation CD into the CD-ROM drive and follow the installation prompts.
Note: If the setup program doesn't start automatically within a few seconds, you need to manually start the installation process.
To manually start the installation process:
  1. Click Start from the taskbar in the lower-left corner of your computer screen.
  2. Open the Run window and type d:\setup in the text area.
    Note: The "d" indicates the path to your CD-ROM drive. If your CD-ROM drive is located in a different path, you need to replace the "d" with the correct path.
  3. If you've downloaded the most recent software driver from the webcam manufacturer's website, run that installation program now.
    Note: Most webcam manufacturers maintain the latest webcam software drivers on the download or support areas of their website. Just download it and save it to your computer.
  4. Follow the instructions provided by the webcam setup program.
    Note: Plug in your webcam USB cord only when prompted. (This is usually done after rebooting your computer.)
My computer says CD-ROM is not available Path '1' cannot be found verify you have access to this location and try again find instalationumms1 in folder and install
Type DEVICE MANAGER in your windows search area
This will show all your computer's hardware and peripherals
Is your CD drive listed?
No-power or other problem
Yes-driver issue?
right click on the cd drive and select PROPERTIES
first tab GENERAL shows if device is working properly or not
click DRIVER tab and select UPDATE DRIVER
You may have to restart.
Please reply if this does not remedy your error.
And always specify what version windows you use.
Hope this helps.
2answers
I need a sound driver and a video driver
ok. Start by loggin to ur laptop manufacture's website,
exaple Dell.com, Toshiba.com. HP.com, any
then go to support then find drivers and download area it will ask you for the computer model example dell inspiron i5200 , or HP paillion .. etc. then look for the audio or video. and download it.
Where can i find a software download load for teac usb 2.0 tv tuner
To download TV Wonder USB 2.0 driver read the instructions below. If you have any other questions please let us know by contact form.
ar.gifDownload ATI TV Tuner / Card Driver dev_img.gif May be useful for you: Please, enter verification code:
verimg.php Refresh
Download Clicking this button you agree with our Disclaimer a
DOWNLOAD LINK:::: http://www.nodevice.com/driver/TV_Wonder_USB_2_0/get34949.html
vote for me
1helpful
Volume icon in taskbar
You experience one of the following symptoms on a Windows XP-based computer:
* The Volume icon is not displayed in the notification area at the far right of the taskbar.
* When you try to add the volume control icon to the notification area, you receive the following error message: "Windows cannot display the volume control on the taskbar because the Volume Control program has not been installed. To install it use Add/Remove Programs in Control Panel. "
Therefore, you cannot start the Volume Control program and cannot adjust the volume and sound level settings of your computer.
There are two possible causes of this problem:
* The Volume icon has not been added to the notification area of your computer. (The Volume icon is not displayed automatically when you first install Windows XP.)
* The Sndvol32.exe file is damaged or missing.
Solution:
Method 1: Add the Volume icon
To add the Volume icon to the notification area of your computer, follow these steps:
1. Click Start, and then click Run.
2. Copy and paste or type the following command in the Open box, and then click OK:
mmsys.cpl
3. Click to select the Place volume icon in the taskbar check box.
4. Click OK.
If the Volume icon is displayed in the notification area of your computer, you are finished. If you cannot add the Volume icon or if you receive an error message when you try to add it, the Sndvol32.exe file might be damaged or missing. Go to method 2.
Method 2: Save a new copy of the Sndvol32.exe file on your hard disk
If the Sndvol32.exe file is damaged or missing, you must extract a new copy of the Sndvol32.exe file from the Windows XP CD and save it on your computer's hard disk.
Prerequisites
This method requires you to have your Windows XP installation CD.
To extract a copy of the Sndvol32.exe file from the Windows XP CD and save it on your computer’s hard disk, follow these steps:
1. Insert the Windows XP CD into your computer's CD drive or DVD drive. Press and hold the SHIFT key as you insert the CD to prevent it from starting automatically.
2. Click Start, and then click Run.
3. Copy and paste or type the following command in the Open box, and then click OK:
cmd
The command prompt opens.
4. Type the drive letter of the CD drive or DVD drive, type a colon, and then press ENTER. For example, if your computer’s CD drive is drive E, type the following, and then press ENTER:
e:
5. Copy and paste or type the following, and then press ENTER:
cd i386
6. Copy and paste or type the following, and then press ENTER:
expand sndvol32.ex_ system_root\system32\sndvol32.exe
Note: system_root is the path and folder name where the Windows system files are located on your computer. This is usually C:\Windows. If the folder that contains the Windows system files on your computer is C:\Windows, type the following, and then press ENTER:
expand sndvol32.ex_ c:\windows\system32\sndvol32.exe
Note There is a space between "ex_" and "c:\windows" in this command.
7. Type exit to exit the command prompt, and then press ENTER.
8. Verify that you can start Volume Control and that the Volume icon is displayed in the notification area (if you selected this option in method 1).
Hopefully the Volume icon is now displayed in the notification area.
Driver lost
You can go to the store (like best buy or even shopo-ko maybe) and go to their computer section of the store then look in the computer gameing area and it should be in there... :)
Having trouble installing
thats ok just go to www.cannon.com under suport drivers software downloads area type in your model then vista or xp whatever u need save new driver to hard drive sumware then install it ok
Lost installation software CD
What type of MP3 player are you using? The first place I would check would be the manufacturer's website for software and drivers. Let me know.
Chris
Top Soyo Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
