Sony Cybershot DSC-S950 Digital Camera Logo
Posted on Sep 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unable to change the time settings
I wanna change the time and date settings but I could not find a way to do so
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Sep 19, 2009
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2957552
Points
33084
In Sony DSC-S950, press Menu button, go to Setup menu, Clock settings and adjust time and date, press OK, press Menu button to exit.
Thanks.
2006 Buick Rainier. How do I change the date?
To change the date on a 2006 Buick Rainier, you will need to follow these steps:
  1. Press the "Time" button on the radio to enter the clock setting mode.
  2. Use the "Hour" and "Minute" buttons to set the current time.
  3. Press the "Month" button to enter the calendar setting mode.
  4. Use the "Month," "Day," and "Year" buttons to set the current date.
  5. Press the "Time" button again to exit the clock setting mode and save the new date and time.
If you are unable to change the date using these steps, it is possible that your vehicle may have a different system for setting the clock. In that case, you may need to consult the owner's manual or contact a Buick dealer for further assistance.
How do you change the date and time on a type 2310
If thats a Nokia phone .I used to have one and if I remember rightly . You go into menu then settings and scroll down to date and time settings . You should be able to set it up alright
Aug 14, 2014 • Cell Phones
How do you reset date and time?
Right Click on the clock in the bottom taskbar then Change date and time settings
this will vary depending on your operating system
hope this helps
1helpful
2answers
How do i change the time and date on my Sansung GT-B5722, it is set on the 01 01 2009?
you may wanna try this:
Create and view world clocks Learn to view the time in another region and set world clocks to appear on your display.
Create a world clock
1. In Menu mode, select World clock.
2. Select Add.
3. Scroll left or right to a time zone.
4. To set daylight saving time, select 1.htm92.gif.
5. Select Add to create your world clock.
6. To add more world clocks, repeat steps 2-5 above.
Add a world clock to your display
With the dual clock widget, you can view clocks with two different time zones on your display.
After you have created world clocks,
2. Select the world clock you want to add and select More → Set as 2nd clock.
I have an Olympia CPD 430 Desk Calculator - I am unable tro change and save the date
Hold the X time set for 2 sec, then set with % the date to 2000-01-01 . Now set the exact date and press once on te X time set.
The date will be saved and with the % key you can change the view of the date to the one you like .Ex 13-06-2011.
Unable to set the correct date. Able to get to menu:additional functions,timer settings and the date and time settings, but unable to change the time
Type everything in and then press OK. If its showing up on scan time then go to Add Funct-System-Date and Time. Make sure time zone is set correctly
3helpful
2answers
Can't change date or time on my new Pentax K2000
Date/time are set at "first use" or through the tools menu.
Remove the batteries.  Leave the camera overnight, this may be enough to lose the current settings and allow setting new date/time.
Press Menu button.
Press right arrow on the 4-way controller to get the Tools (spanner) highlighted.
Press down arrow to get to date (or time).
Press right arrow
Now set to your preferred format.
If this does not work, try changing another item in the Tools menu.  If that change is not accepted, then it's into the dealer.
7helpful
2answers
Wrong time
To set the time do the following:
Setting the date and time
Press the Back/Options button ((the left pointing green arrow)).
You may need to do this more than once until the main menu appears.
Select Extras Date & Time. The current date and time are displayed.
Press and hold the Back/Options button.
Select Set Time or Set Date to change the time or date settings.
Select Date Separator, Date Format and Time Format to adjust how the date and time are displayed.
Select the options you want.
2helpful
Unable to change today's date on new Samsung SHG-D980
To change the date select:
menu, settings, time and date.
Drag down the screen until you reach the Date box.
press once, press a second time.
enter the date and press OK
save and exit
hope this works, it worked for me and I had exactly the same problem.
103helpful
12answers
I do not know how to set my clock on my razr after the time change last nite
Settings
Initial Setup
Time and date
  • Turn AutoUpdate Off
select and make the change
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
