Can you upload pictures from a file to the camera memory card in order to put it in a digital frame? Or do you need a memory card reader? It won't let me add the file back onto the camera. Thanks!
This model doesn't allow you to upload photos from a PC to your memory card whilst the camera is connected to the PC. You will need a memory card reader.
The Pandigital picture frame saves its image files on the memory card. You can put pictures in memory card by inserting it to a memory card reader on the computer and copying pictures to it. Tthe picture frame, then reads the files on the memory card.
Should you need further assistance, please let me know. Thank you for using FixYa.
Ok what you need to do is you need to put your memory card into your computer/mac and down load the files once that is done delete the photos on your camera!
On one side of the frame there should be memory card slots and a usb slot.
two ways to do it, take the memory card from the camera and put it in the frame.
Or down load the camera to tyour computer and then with a usb cable upload the picture fram with the pictures you want
Or from your computer load a memory card and then stick it in the frame
If the "camera chip" you refer to is a removable SD Memory Card you need to put that into a SD Card Slot on your computer or use an USB Card Reader device. The computer will recognize the SD Card as a Disk Drive and you can use Windows Explorer to transfer the picture files to it.
Yes, you can upload picture on memory card in camera and can playback in camera as well. Make sure that picture files are JPG format and file name must be DSC00001 to DSC99999, other then that camera will not show file in playback though memory card have it. Connect camera with computer, click My Computer >> Removable Disk >> 101MSDCF folder and copy / paste files there.
1.) You can insert the Memory Card directly into the Frame
2.) You can connect to your PC or MAC with the camera (Memory Card still inside the Camera) and Upload the Photos to a File. Then Connect your Frame into your PC or MAC and download them to the Frame.
3.) Connect the camera directly to the frame. (This may cause formatting issues though)
When the camera writes the image files to the memory card, it also creates index/information files. Without those files the camera will not display the images.
Check the software you used to upload the images with. There's probably a checkbox or option that tells it to delete the images from the card after uploading them.
I just purchased a frame and wondered the same thing. My computer has a slot for an SD card once inserted the computer shows the SD file. Then go into where you store the pictures highlight the picture one at a time in the picture file my program says copy to file click on it and shows the SD file as F file click copyit then downloads to the card. Done put SD card in frame worked perfectly.
