Flashing the bios is just simply installing an updated version of bios, you can try to install this one : http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R138835&SystemID=LAT_PNT_PM_D505&servicetag=&os=WW1&osl=en&deviceid=4836&devlib=0&typecnt=0&vercnt=5&catid=-1&impid=-1&formatcnt=1&libid=1&fileid=185806
just click on download now, continue and follow the prompts , the computer should restart and when it turns back on, it should work.
Testimonial: "Thanks for explaining what last Flash BIOS means....... But I did that I have A11 from dell. I think it is more of a battery issue"
You don't flash your BIOS to edit the NUM lock key, you get into BIOS and change the setting from NUM LOCK ON to NUM LOCK OFF. YOu enter th eBIOS area and edit the NUM ock setting, scroll keys aren't in there, so I am not sure what you are experieincing with them
If you have to ask you shouldn't be messing around with your BIOS, or even worse Flashing it, you could do a lot of damage if you don't know what you are doing.
Here is the link to the Dell D505 Bios download page and instructions. Be sure that this is the correct one for your computer or you will make your laptop un-usable if you install the wrong BIOS!!!!
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R138835&SystemID=LAT_PNT_PM_D505&servicetag=&os=WW1&osl=en&deviceid=4836&devlib=0&typecnt=0&vercnt=5&catid=-1&impid=-1&formatcnt=1&libid=1&fileid=185806
The file D505_A11.EXE is using the Hard Drive format and is designed to be directly executed from Windows environments.
The File Download window appears.
The Save As window appears.
A progress meter moves as the download is completed.
NOTE:
Shut down all other applications prior to running the BIOS update utility. The update utility reboots your system in order to get the new BIOS loaded.
The Dell Bios Flash window appears
The message Pressing OK will close all applications, shut down Windows, Flash the BIOS, then reboot. appears.
The system will restart and the Bios Flash will be completed.
