20 Most Recent
Dell Computer Refurbished OPTIPLEX SX270 SYSTEM BOARD Computer Motherboard Questions & Answers
No video upon start. fan ok, drive sound ok, all
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they might be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions even something as small as an electrical fan and its lead can cause this problem or just replace them they could be faulty a computer needs all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove yor graphics card restart your computer then reinstall it should activate found new hardware wizard
hope this helps you
What does "RUNDLL Error loading newdev.dll" and
newdev.dll is the Windows file that is responsible with the recognition of the hardware and the loading of the drivers - an absolutely critical file. This file is severely corrupted and the only way to fix that is to perform a Repair install.
I recently bought an old dell optiplex sx 270. I
You are limited in the choices for video card The Optiplex GX270 only has a 160W
power supply Not only that but because of the slim case, you're most likely limited to low profile
video cards. That means the choices will be extremely limited & not very good. Even after the upgrade, you'll most likely have to stick with older games. follow this link to buy low profile video cards
http://www.directron.com/lowprofile.html
Re-installed windows xp on dell optiplex SX270 and i've no sound
Begin by checking device manager. If there is a Unknown device or PCI device listed but not properly installed you will need to identify your audio chipset and downlaod and install the correct driver. 90% of all onboard audio chipsets are AC 97' by Realtek.
If you need help in locating the drivers just post back.
No Response from keyboard or mouse
We must have an epidemic. The person before you had just about the same problem, but his was worse. I know a Dell Optiplex. I had one and I installed Linux. Then I found it had a loose connection between the video socket and the MB. I will need some information of what happened, so we can duplicate your problem in our laboratory and be able to give you concrete info. Thank you for considering our service...
My name is Constantin (arzconst)
No keyboard or mouse response
Hi, Check in your Bios if Usb keyboard and Mouse Support is enabled, otherwise you can use a Ps2 Keyboard just to get to the desktop, then you should be able to install your keyboard and mouse, yor pc should automatically detect the devices
PC won't start up
Hi There,
I would suggest you test it with another Power Supply, or check you Ram, Let me know if successfull or not?
Cheers
Techmor
Hou do i reset bios on a dell optiplex sx270
- Boot up the computer into the setup (depending on your bios, to get into the bios you need to hit the DEL key during boot up.)
- Press 'ALT' and 'F' at the same time
- Turn 'NUM LOCK', 'SCROLL LOCK' and 'CAPS LOCK' on. (Make sure the lights on the keyboard are on.)
- Press 'ALT' and 'P' at the same time. The bios should now be reset to the factory settings.
Orange led on mother board
You have a hardware failure, most likely memory or video card. The first thing I would try is open the case and blow the dust out of it, especially dust on the memory modules and anywhere on the motherboard. Then try to boot the computer again. If that does not work I would start removing components one at a time and testing them.
Blown dell motherboard
Have you checked to make sure it wasn't the power supply? If this motherboard is still inside the pc and the cd/dvd lights up, or the network card shows life, fans, case lights, etc: than I would rule bad mobo. If nothing shows signs of life, try power supply or even better maybe a lose connection.Check all cabling and wire plugs. Clean out any dust.
I want to know about some adventures video games?
Check out Big Fish Games. It is a subscription service but they have all types of games including adventure and hidden object. You can also tryp Pogo since they have both a fee and subscription service. Last, but not least, you can try one of your local computer stores or the electronics section of "big box" stores like Target, Walmart, Kmart, etc.
