SOURCE: Electrolux DX302 Dishwasher power button wont stay on
I rang Electrolux and have ordered a new switch....
SOURCE: Kitchenaid dishwasher door does not stay up in the open position.
On each side of the dishwasher, near the ground, is a nylon cord and pulley apparatus that keeps the door from flopping down when opened. It probably needs some adjustment of the tension on the cord.
SOURCE: Electrolux Dishlex Door wont shut
spring it catch still working you just may need to replace it
SOURCE: dishwasher door
You're right a spring has either snapped or come off of it's anchor point. Should be 2 ...one on each side of the door. you can order parts on line at several appliance replacement part suppliers... have your make and model so you'll get the right parts. K
SOURCE: 23 in. Novotronic G841 Built-In Dishwasher: the door on my miele G481 built in dishwasher won'...
hi,
you need to adjust the door tension springs which is by a screw each side of the hinges on the plinth of the unit at the front. There is a symbol of a spring to show you which screws to release. do them evenly and the door will not spring up,
Hi Peter Gumbrell - Often when the dishwasher door does not lock, it is because the of door lock assembly. The door lock or latch may either be faulty or damaged. If I was in your position, I would personally recommend consulting a professional to accurately diagnose the dishwasher to determine the root cause to reduce the risk of unnecessary parts.
