Re: 23 in. Novotronic G841 Built-In Dishwasher: the door...
you need to adjust the door tension springs which is by a screw each side of the hinges on the plinth of the unit at the front. There is a symbol of a spring to show you which screws to release. do them evenly and the door will not spring up,
what you need to do is slack off the spring tension on the door hinges. each side of the unit at the base on the plinth there is a screw with a spring symbol next to it. turn this anti clockwise to reduce the spring tension.
rarely. next time this happens. immediatly go to the breaker box, and feel for heat on the breaker that is blown. if it is warm, your miele is okay, call an electrician.
I had a similar problem with a different Miele. I found that under the door, there is a removable trim panel (may not be one on yours). Under the trim panel was an acoustically sealed metal plate held by a couple of screws. i switched off and disconnected the electrity, then removed the plate. The bottom tray was filled with a big puddle. I cleaned that up and put the machine back together and it ran fine. Accordingly, I'm getting some replacement shaft seals for the thing as it looks like its worth fixing. Good luck with yours. rupertvdP
This same problem is posted elsewhere on this site. Probably you need to clean out a valve on the bottom of the machine (inside the dishwasher). Check your manual, or the similar post on this site.
