My washing machine is locked with the 5E code displayed. I previously drained the machine as it was making a grinding sound. When I removed the filter cover the drain pump propeller had come off and now I can't get it to fit back on. Can I buy a replacement propeller? Thanks in anticipation.
SOURCE: Washer still wont drain, even after cleaning drain pump line
"F02" is a Long Drain error. If you have managed to verify that the drain lines are clear from the tub - to the pump - the the wall, then this usually indicates that the pump has failed. It can be common for this pump to make noise and still not work.
Just to be sure: Is water running freely form the tub to the drain line when you drain the water? If not, make sure you double check the line from the tub to the pump. Is can be common for small articles of clothing (i.e., wash cloth or underwear) to get caught in this area and restrict water flow. Don't ask me how these items get between the wash tub and basket, but I have seen it happen.
The pump is usually sold as a complete unit and can be found at searspartsdirect.com. Just type in your model number and the part will be listed under the "Pump & Motor" heading. It is listed as item #10 (part #8181684) and sells for about $71.00.
This is a fairly simple job that you can accomplish yourself if you feel inclined to do so. If you click on my profile and look under "Tips and Tricks", I have step-by-step instructions posted on how to replace a drain pump like yours. If you cannot find the information you are looking for, please post back and I will assist you further. I hope this answers all your questions.
SOURCE: how to get back off to put belt on samsung b1445s washing machine
See if the motor has adjustment , ie a slotted fixing hole, slacken the fixing bolts slightly and motor may move up and down to give adjustment, put the belt on and then put some tension on the belt once fitted by moving the motor down and tightening the motor bolts at the same time.
Or if no adjustment put the belt on the motor spindle first and then the drum by turning the drum as the belt is eased onto it.
SOURCE: Drain pump removal on Zanussi FJR1254 Washing Machine
not easy.suggest you disconnect pump and power up independently as an easy way to check if it runs
easiest way to remove pump - and its awkward - is to undo the 3 screws holding the pump to its housing
SOURCE: miele W1712 washing machine drain fault
Just had the same problem, after Much patience and persistence I found the blockage at the y piece that joins the pump to the outlet hose air trap towards the top of the machine LHS with the top and cover off.
It was clogged solid therefore no back pressure on the top little ball valve (between the air trap and the outlet) therefore no seal therefore norain therefore a drain-fault that persists regardless of a cleaned pump filter.
WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
