A lock password is set at the extension. If you lost the password, your system manager can clear it for you.
You might want those instructions in an open forum, but I'm guessing your boss or you as an employer do not.
You may take this to email by [email protected] Have your system model number and use Lock Password as the subject. You might want to provide a little bit more information about yourself in the post.
To reset a bike lock with letters, you would not need a key to lock and it more convenient to use. There are two ways to reset your bike lock with letters. You can try to unlock the bike lock with the default combination provided by the manufacturer. It is usually effective and will allow you to reset the lock. When you reset word lock bike lock with letters without password: you have to use force to pull the ends of the bike lock. Then, twisting the rings and take a chance of guessing the correct letter of a particular hole. Finally, rotate it clockwise up to 180 degrees, set your new passcode.
Depends on the type of phone there might be away to unlock it. If u have a online account were u can lock and locate it. There might be a function of to change the password online. Call customer service. if you don't mine losing everything on your phone. There's most likely be a reset button on the phone, which will reset your phone to default. Common places would be on the side for phone without access to battery. Or under the battery compartment. It would be a small hole just big enough to insert a paper clip. Check your owners manual for it location. Tip. If u r forgetful. Try having a lock file on file with your passwords.
I will help you to reset the phone password ,you can please specify the Mobile Phone brand and model,you can reset the phone password using the master reset code .,If it nokia means you can try the default code 0000 or 12345 or 1234 if not works means you can get the master reset code from the site www.unlock-free.com for Nokia DCT phones and Alcatel phones and reset from security lock or password lock.
what is Your Phone brand and Model? You can reset the Phone using the master reset code,You can get the master reset code at here Unlock-free.com and reset it....If your Phone Nokia or Alcatel means get the master reset code and reset from PASSWORD LOCK.,..
If your Phone Does Not accept the Password means You need to reset the Phone from the Password Lock,Because i think You forgot the Password Code..If your is Nokia or Alcatel Mobile Phone means get the master reset code at here Onlinegsmunlock and reset it from Security Lock or password Lock.
Perform a hard reset by holding the talk and answer buttons and then inserting the stylus in the reset switch hole. This will erase EVERYTHING on the phone, including the lock. Once again, the phone will be like brand new... EVERYTHING WILL BE ERASED.
you can reset your phone by pressing the master reset pin that you can find at back of the fone where battery is placed or at the bottom . insert a pointed thing inthat hole and the phone will ask you to reset or not make it yes and your phone will be reset.
but make sure you by mistake don't insert anything in the phone's mic hole at the bottom of it .
