if you have saved your google mail in it, then u cud certainly recover from it. But if you have not done that , then i am afraid you will have to factory set .. using switch off and reset by pressing volume n power buttons depending upon model n make of mobile phone.
Contact Norto :
Chat
Chat support is available 24 hours a day, 7 days a week.
Estimated wait time: 5 minutes CHAT NOW
Phone
Phone support is available 24 hours a day, 7 days a week.
30 minutes Call Us
Email
Solutions delivered to your inbox
A fireman's switch is not required, and usually not even "recommended". It is usually mentioned in the instructions only in the event you want to hook it up. The switch is actually a remote tied to a timer that turns the heater off ~20 minutes before the pump to save the gas and use up the remaining heat energy in the exchanger as the pump finishes it's cycle.
Was your phone fully charged before you started the game? Has it now run out of battery. Recharge it fully and try the game again. Some old batteries do not hold their charge long.
Q1. Engine will not start or is hard to start (Cranks OK)A1 -Ignition lock switch faulty-Ignition coil faulty-Power transistor faulty-Spark plugs faulty-Ignition wiring disconnected or broken-Spark plugs faultyQ2,
Engine will not crankA2.
Battery dischargedBattery cables loose, corroded or worn outTransaxle range switch faulty (Vehicle with automatic transaxle only)Fusible link blownStarter motor faultyIgnition switch faultyIgnition lock switch faultyREMEDYCharge or replace batteryRepair or replace cablesAdjust or replace switchReplace fusible linkRepair starter motorReplace ignition switchReplace ignition lock switch
