Toshiba Satellite A205-S5831 Notebook Logo
Posted on Aug 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to reset "A205-S5831" CMOS Password - Toshiba Satellite A205-S5831 Notebook
steveparlin
Level 2:
Scholar:
  • Expert 61 Answers
  • Posted on Aug 31, 2009
steveparlin
Expert
Level 2:
Scholar:
Answers
61
Questions
0
Helped
34580
Points
152
This information is kept confidential by Toshiba. The only method I am aware of is by calling toshiba tech support. I Know they will ask for your information as well as proof of purchase. I "think" they may even require the machine to be sent to them.
Unfortunately this is the only method I am aware of to clear the bios/cmos password on a toshiba.
How to remove CMOS battery for A215-S7444? I done a search and got this answer: "This should help: * Remove Laptop Battery * Remove Memory Cover * Spread spring clips to outside and * pull out RAM...
What are you trying to do? Replace the CMOS battery, or reset a BIOS password?
This is what the CMOS battery looks like,
http://www.ebay.com/itm/CMOS-RTC-Battery-Toshiba-Satellite-A210-A215-Series-/270970735656?_trksid=p4340.m263&_trkparms=algo%3DSIC%26its%3DI%252BC%26itu%3DUCI%252BIA%252BUA%252BFICS%252BUFI%26otn%3D15%26pmod%3D160437620636%26ps%3D63%26clkid%3D8748715535548215160
Now view this pictorial disassembly guide,
Page 1 - http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
Page 3 - http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-3.htm
Go to the photo in Step 17, and click on it to enlarge.
See the CMOS battery in the middle/left?
Round silvery looking object. Go straight down from the red arrow to the far left.
That is how to access the CMOS battery.
(Yes I know it states Satellite A200/A205. Same for the A215)
Now BIOS password reset?
Do not know where the two copper pads are to briefly short out. Suspect under the Ram Memory modules, (And under a small sheet of Mylar plastic), or under the Wireless Modem. (And under a small sheet of Mylar plastic)
The links on this solution I gave may help,
http://www.fixya.com/support/t6645137-toshiba_l500_clear_cmos
For additional questions please post in a Comment.
Regards,
joecoolvette
[ Am I concerned that you may have stolen the laptop, or are trying to break into someone else's laptop?
NO
Your real name, and IP address are recorded on FixYa, to give to the authorities, if needed.
I figure a thief would not risk this ]
How to reset a password to toshiba A205-S5804
To enter in to bios, try password Toshiba.
Also:
By UsingMS DOS Command: This methodworks only if you have access to the system when its turned on because thismethod requires MS DOS. Open Command Prompt from Programs menuand provide following commands one bye one: Debug o 70 2E o 71 FF quit NOTE:The first character in the above commands is English alphabet "o"and not the number 0. After providing the above commands, restart your systemand it should reset the CMOS Settings along with the BIOS password. If you arecurious to know how it works? then let me explain the above commands: In this method we are using theDebug tool of MS DOS. The "o" character present atfirst in these commands, outputs the values to IO ports. The number 70and 71 are port numbers which are used to access CMOS memory.By providing FF value we are telling CMOS that there is aninvalid checksum and it resets the CMOS settings as well as BIOS password. By UsingSoftware: There are a few software which canalso reset CMOS settings or BIOS password or both within a few clicks. But asstated above you should have access to a system which is turned on and shouldhave access to MS DOS or MS Windows: CmosPwd . You can download program on this page: http://www.cgsecurity.org/cmospwd-5.0.zip
1helpful
Hi I forgot my password for toshiba satellite 205 cds , for bios . What I can do ? Please HELP Emanuel
You can reset bios password with 2 method.
(1) open back cover of laptop then find motherboard .Pull cmos cell from motherboard for 15 minutes then again put it in it's position .then it not ask for password.
(2)You can clear password with jumper settings find jumper on motherboard named clear cmos it has 3 pin .1-2-3
Put jumper in 2-3 position then again put it in 1-2 position then check .
Let me know if you need more assistance.
Thanks.
5helpful
3answers
My toshiba a205 s5804 is asking me a bios password
remove ac supply and battery from the laptop.. and press power button for atleast 30 sec.. it reset the CMOS memory.. this is what toshiba technical support person told me to do when i called to them way back..
Toschiba satellite A205-s5843 el producto pide
You need to remove CMOS battery and leave it 12 hours as is. Try again see if cleared. Check if there is a reset button under laptop?
Google it how to remove BIOS password, you will come up some codes.
Sir my toshiba laptop is under bioword and i donnot know password .sir, listen how to open motherbroad satille a205-s5861 thank u sir
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Then it not want password.
1helpful
BIOS Locked
You should be able to reset it by disconnecting the CMOS battery. Unfortunately, you have to partially disassemble the computer to find that battery. I really can't tell you where it is, but in some computers you can access it through the main battery enclosure. The motherboard may have a jumper that has to be reset to clear the CMOS memory or maybe just disconnecting the battery will do it.
Finger print sensor not working with vista in toshiba M200
here is the link :
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2211892&rpn=PSMC4U&modelFilter=M205-SP3018&selCategory=3&selFamily=1073768667&selModel=2211892|PSMC4U
Satellite A200-ST2041, A200-ST2043, A200-ST2042, A205-S4617, A205-S4618, A205-S4639, A205-S4638, A205-S4537, A205-S4557, A205-S5816, A205-S5814, A205-S5813, A205-S5812, A205-S5811, A205-S5810, A205-S5809, A205-S5806, A205-S5805, A205-S5851, A205-S5847, A205-S5843, A205-S5841, A205-S5835, A205-S5831, A205-S5825, A205-S6810, A205-S5823, A205-S5804, A205-S5803, A205-S5801, A205-S5800, A205-S7468, A205-S7466, A205-S7464, A205-S7459, A205-S7458, A205-S7456, A205-S7443, A205-S7442, A205-S4797, A205-S4787, A205-S4777, A205-S4707, A205-S5863, A205-S5859, A205-S5855, A205-S5853, A205-S5852, A205-S6812, A205-S6808, A205-S5821, A205-S5819, A205-SP5822, A205-SP5821, A205-SP5820, A205-SP5818, A205-SP5817, A205-SP5816, A205-S5000, A205-S5866, A205-S5879, A205-S5878, A205-S5872, A205-S5871, A205-S5867, A205-S5880, A205-S5861, A205-S5833, A205-S5864, A205-S4629, A205-S4607, A205-S4597, A205-S4578, A205-S4587, A205-S4577, A205-S4567, A215-S4697, A215-SP5811, A215-SP5810, A215-S48171, A215-S4817, A215-S4807, A215-S4767, A215-S4757, A215-S4747, A215-S4717, A215-S4737, A215-S5839, A215-S5848, A215-S5837, A215-S5829, A215-S5828, A215-S5827, A215-S6820, A215-S6816, A215-S7472, M110-ST1161, M115-S3094, M115-S3104, M115-S3154, M115-S3144, M200-ST2001, M200-ST2002, M205-S3207, M205-S4804, M205-S4805, M205-S4806, M205-S7453, M205-S3217,
2answers
Forgot Bios Password
unplug cmos battery then plug it back in make sure laptop is unplugged fist
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
