the power light on the back of the pc? try switching off the power at the socket and leaving it powered down for 5 mins and re trythe power light on the back of the pc? try switching off the power at the socket and leaving it powered down for 5 mins and re try
Can you clarify a little. Is it the monitor or computer that will not turn on?Can you clarify a little. Is it the monitor or computer that will not turn on?
You can't post conmments that contain an email address.
It sounds like the CPU is over heating. It probably has poor ventilation. Unplug the unit and open the side panel. Carefully vacuum all the dust inside. Be careful not to damage any electronics. You can use a small brush to loosen the dust before vacuuming. Good luck!
you bringing a marginal part or connection back up a working state. when it cools or voltage drops it goes to the non working state. hp power supplies are not good to begin with. replacing it will fix it till that one also fails
fully charge your heli----turn on transmitter-wait 2 seconds-turn on heli wait for blinking green led to stop blinking-turns steady.....rev up with a quick full throttle and back to idle--happy flying
hi.. It's in standby mode. Do a reset and see what happens While holding down the reset button on the remote Press the power button on the tv (The tv will turn itself off the back on) Now release the reset button
It sounds like the lamp needs replaced....
It will have to be diagnosed. As the only blinking light error for that model is when the led turns from green to flashing red which indicates a lamp error. If its new I recomend returning it most retailors will freely exchange a new TV . Wish I could help more but there is no diagnostic codes for that model other than lamp error. And being that I am taking that the back light isnt working either. I would contact the retailor without delay.
hi, the blinking is caused by a fault in the printer, means it needs to be serviced, its usually more expensive for them to fix it than buying a new one, but you can get there number off the canon website.
