Have you tried running repair my computer and system restore, either from the F8 menu or from a recovery disk? Try that to begin with, or run startup repair.
Otherwise, some good suggestions in
this post. unfortuanately, you're not alone.
Among them this one:
A simple solution to resolve this black MS screen follow the below
steps:
1- Run Vista with safe mode command prompt
2- Type “msconfig” and hit Enter key,
3- select “Diagnostic Sartup” option, click on Apply then OK
4- System will ask restart the PC, choose yes,
5- System will start logging off but it will stuck at this stage, force
your PC to shutdown by pressing and holding on the power button until it
is off
6- Start your PC “et Voila” it will work
Note:
- it is possible that some of your services will not start or function
properly (this is an other problem)
- This solution tested on Vista Home Premium 32bit OS
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Hello, Does the machine belong to you, or is it just rented?
