It was working with 1/3 dark picture on the bottom screen , then when I turn on, green light on power button lite up 10-20 secs on then turns off thanks.
Try this: 1) turn on the TV 2) from the remote control press MENU 2,4,7,0 then ENTER 3) tv will state on screen that it is INITIALIZING 4) when done press the front reset button. 5) should be good to go!
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
This sounds as if you are using the hibernate feature in windows reboot it and reset the power options to hibernate never check the vid connection as well
I think there is a button on the bottom left of the bottom touchscreen where when you turn on the system even if there is no picture you should be able to tap it and change the screens brightness just by pressing this button. Its in the very bottom left corner
This is a problem with the cpu on the systemboard. I've seen this problem many times if the DS Lite is felt to the ground. The contacts of the cpu are very fragile. The DS Lite turns on, green led available, even charche is working bot nothing else. Repair of this problem is almost impossible. The only thing you can do is send it to Nintendo.
You can test if it is the cpu by removing the bottom of the DS Lite and put the battery on te contacts. Press firmly on slot 1 (the aluminium cover) and turn the DS Lite on. If you got a picture on the screens then you know it for sure. The cpu is located under slot 1 and by pressing on de top of the slot you are pressing possible loose contacts back on de systemboard.
If it is not working then the cpu is to musch damaged.
When you boot the Nintendo DS you can change the illumination settings in the main menu. One the main menu, you will find a sunny symbol in the lower left corner of the screen. Click on that and you should be able to change the level of illumination. If you are also wondering if you can change the brightness during game play, you can't. Games such as Mario 64 DS come with support for brightness change but otherwise you have to do it before game play.
