The ignition module on this model is bad to go bad,When this truck dies like that again,check to see if it is firing.If it is not giving any spark,replace the ignition module,if it does not fix the problem,replace the pick up coil in the distributor.Ignition coils can cause this also,but the symptom sounds like the module.If I can help,let me know,If you have spark after the engine dies(check for spark after it dies)then check the fuel pressure,and the fuel filter.If the fuel pressure is fine,then the module and the pick up coil need replacing.
Testimonial: "Thanks for the help, but theses have been replaced already , know of anything elese it might be?"
Have you narrowed it down to ,no spark?How about fuel pressure?I am asking these questions so I can help,If you would,answer these questions I can maybe help,and then add input if you would.If you are sure there is no spark when it dies,check the est module on the firewall.It is a flat box,with a wide plug in.Get back with me soon as you can,and we can resolve your problem.
Aug 29, 2009 - Have you narrowed it down
problem.
Aug 29, 2009 - Aug 29, 2009 - Have you narrowed it down
problem.Give me a shout,lets see if we can figure it out.
I meant to say i have replaced these items listed.
