Connect just the speedsteam to your computer with a cable
find the RUN command and type "cmd" then ENTER
on the black screen that comes up type "ipconfig /all"
the number that will be besides the name Default Gateway is the IP
you might also want to write down the numbers by the DNS servers too as these can be useful
Connect your router to computer with ethernet cable.
Then go to start menu then type in run 'ipconfig /all"
you find ip adreses sub net and GATEWAY.
GATEWAY ip is your router ip.
Let me know if you need more assistanse.
Thanks.
SOURCE: speedstream modem 4200
put the modem in bridge mode and then connect a DSL/cable router to it...you'll have to configure the PPOE if its DSL... Cable is a little easier because there usually is a MAC authientication not username and password...plug dsl/cable router into cable modem...turn both off for about aminute then turn modem on first then router... Be careful most routers with wireless have it enable with no security by default...turn it off or set securty (wirelss that is)
SOURCE: Siemens Speedstream 4200 Driver
Visit this link http://www.modemsupport.com.au/. On the left side under the heading Speedstream 4200 download and isntall both the drivers and firmware.
Once you've installed the firmware open iexplorer and goto http://192.168.254.254 . Type in an admin password and save settings. Type in your username and password ( provided by your isp ) press save again and then press connect. you should be in business.
SOURCE: No activity on my new speedstream 4200
Ethernet and DSL lights are indicating you have ADSL available on your line, and that you have computers connected to the router.
What has probably happened is that Optus did not set up the new router with your username and password. Go to thw following website for details on how to setup the modem.
http://help.optuszoo.com.au/help/dsl/connected/windows/optus_modems/speedstream_4200
Manual Modem Settings
The Optus DSL Broadband self-installation CD configures all the necessary settings for your DSL Broadband service. You do not need to manually configure your modem if you have run the self-installation CD. While the following information is provided for your reference, using the self-installation CD is the recommended method for configuring your modem.
The Siemens SpeedStream 4200 ADSL modem can use either USB or Ethernet to connect to your computer.
After connecting your modem there are two key steps to manually configure your modem for the Optus DSL Broadband service:
top
PC Settings
Step by step instructions are provided for each of the supported Windows operating systems:
top
Configure Your Modem
To configure your modem settings you must now access the configuration manager using your web browser. This is done by entering the IP address in the address bar of the browser window as follows:
Note: If you are updating the password in your modem, please complete steps 1 to 3 only.
Step 1 of 5
Step 2 of 5
Step 3 of 5
Step 4 of 5
Step 5 of 5
Once the modem has rebooted and the ADSL connection has been successfully established the DSL LED indicator will light steady green.
Your modem is now connected to the Optus DSL Broadband service.
