I have a Siemens Speedstream 4200 Modem and am trying to get the drivers for this, am putting in http://192.168.254.254 in the address field as I was originally instructed to when I first received the modem but I can't seem to access it now. Do you know where I can get the drivers for this modem? I was with a different ISP when I last used this.
Regards, Debbie
Visit this link http://www.modemsupport.com.au/. On the left side under the heading Speedstream 4200 download and isntall both the drivers and firmware.
Once you've installed the firmware open iexplorer and goto http://192.168.254.254 . Type in an admin password and save settings. Type in your username and password ( provided by your isp ) press save again and then press connect. you should be in business.
Modems dont need drivers, only the NIC in the PC....ensure that the NIC is working properly in the "Device Manager". If not youll need a working NIC 1st. Then youll need to contact your ISP for propper configuration of the modem.
You dont need drivers for this modem.
* Open up your internet explorer, in the address bar type 192.168.0.1
* You can see the configuration page here. In the login page, enter the email address password to go online
Take care
As solution 4 says, if you connect via USB port you DO need a driver since Windows needs to be told about it.
If you connect via a network cable then windows doesn't care.
Further, a lot of modems supplied by service providers are set up for
them only and so need to be reset to the manufacturers original
specifications to work (ie BigPond, I had to use Siemens drivers to
remove BigPond settings. Before I did that http://192.168.254.254 .did not work!)
Modems do need drivers if you use usb connection.
Do I need a driver for connecting this modem via usd port?
I had a modem from optus the speedstream 4200. Now I'm with dodo and want to use it. don't have the cd. In abc terms how do I fix this.
way need to use it using DIAL UP till i do
i need the drivers
I had a modem from optus the speedstream 4200. Now I'm with UZ net and want to use it. don't have the cd. In abc terms how do I fix this.
