You may be able to remove the mirror inner trim panel (small triangular shaped trim piece above door trim panel)
to access the mirror mount.
If not then you will have to remove the trim panel for access to the back side of the mirror
? 8:16
https://www.youtube.com/watch?v=Bmm9M28dqv4
Mar 10, 2014 - Uploaded by bimmermerchant
BMW 540i Side View Mirror Removal 525i 530i. bimmermerchant ..... A truck recently side swiped my ...
? 2:31
https://www.youtube.com/watch?v=uUcpzHx2ZR0
Jan 6, 2013 - Uploaded by AutoandTruckMirrors
This How To video offers you easy step by step instructions on how to remove and replace a broken side ...
? 13:58
https://www.youtube.com/watch?v=ldjeQsnAJ9M
Jan 26, 2014 - Uploaded by Daniel Scheer
This video is a step by step instruction for the removal andreplacement of the side mirror on a 1996-2007 ...
? 3:00
https://www.youtube.com/watch?v=saIEH-CxRkY
Aug 10, 2014 - Uploaded by DIY Mechanics
VW Golf MK4 - how to remove/replace door wing mirror video ... How To install Replace Side rear View ...
? 10:31
https://www.youtube.com/watch?v=tuGFzxCVh7k
May 8, 2012 - Uploaded by 1A Auto Parts
In this video, 1A Auto shows you how to repair, install, fix, change or replace a broken, smashed, cracked, or ...
? 14:20
https://www.youtube.com/watch?v=UKLPkZszbrA
Sep 25, 2013 - Uploaded by Go-Parts
Side Mirror purchased from www.Go-Parts.com Links to purchase products: ...
? 4:06 https://www.youtube.com/watch?v=2LAqSfV-swI
May 23, 2010 - Uploaded by Decibel Car
Want to replace your wing mirrors with aftermarket ones ? Had someone in a shopping mall car park break ...
Remove the screws that hold the mirror and remove it from the door. Attach the new mirror. Reconnect the electrical connector and make sure you test the new mirror before putting the parts back into place. Reverse the entire procedure to reassemble the door trim panel.
If the wing mirror is broken you will need to replace it some time. The fuse that operates the wing mirror probably operated several other circuits as well. My suggestion is to cut one of the wires to the mirror motor and insulate it. This will stop the motor from running without affecting other circuits.
Hello Darren, there is not special tools required.Just open the plastic cover from inside/against the mirror and you will see 2 or 3 bolts with 5 mm Allan key head.Good luck
There is a black plastic cover on the other side of the mirror, take it off make sure you have the wires long enough to splice back to you will be able to see all the bolts that need to come off to replace the mirror. You will be able to figure out the rest it is very simple
