Is fan running.? Is outside unit running? Check to see if you have float switch on Air Handler inside. This is located in the drain line or drains into a container with a switch in it. If this is tripped or water in pan the drain is stopped up. You can clear the line with a shop vac by sucking from outside. There may be otherproblems but I would start withe easiest. Drain switch , check breakers, theen if that does not work calla service tech for free estimate. Russ
whats not running indoor or outdoor unit or is it all outside have you checked the breaker and disconnect at outdoor unit
