Freezer no longer freezes. It's the same temperature as the refridgerator section though both are set for maximum cooling, door seals are fine, etc.
Could this be due to partial loss of refridgerant or otherwise mal-functioning compressor--or to something else?
Sound like you said a sealed system problem if compressor is running check the black coil under ref by the fan and see if it is warm if not you have lost freon just trash it then if it is see if fan in freezer is running if so pull back cover in freezer and see if coil starts to freeze if you have a ice block on coil then it is a defrost problem good luck
how do you replace ice chute door 12562701 on amana side by side refridgerator ARS266ZBC
tabs broken on ice chute door
