This problem & restart problem is very common for 3110c,temperorily it can be fixed by changing the memory in use ,but for permanent fixing format the memory card ,if continuous with ame format the cell,hopefully formating the memory card will solve the problem
Determine how the camcorder works. There are 3 basic modes of capturing stills with a camcorder. Read your instruction manual for specific information.
Step 2
Understand freeze-frame stills. The most common and least effective method is a "photo mode." Basically, the camcorder will simply freeze a frame of video for a few seconds, which can then be extracted later as a still.
Step 3
Use editing software to capture stills. This method is similar to the first, and can be done with any camcorder. Download an editing program or use the camcorder's bundled software. Then transfer the video over to your computer and use the software to pull out stills.
Step 4
Understand built-in digital cameras. This is a more expensive option, but results in higher quality photos. These cameras have built-in memory cards and function basically the same as a stand-alone digital camera. Refer to the manual to switch over to digital camera mode, then point and shoot. The photo quality is usually a bit lower than from a stand-alone camera.
Step 5
Compare specifications. Understand that specifications for high quality video don't necessarily translate to high quality stills. CCD determines the quality of video, while megapixels determine the quality of stills.
Step 6
Consider the value. Whether or not a combination digital camera and camcorder is best for you depends on how you'll be sharing your photos
Normal
0
Double Click on this site http://www.free-codecs.com/download/AMCap.htm
to download the Free AMCAP Video Capture Program.
AMCap v9.20
AMCap is a small yet fully
functional video capture application compatible with Microsoft DirectShow. It
is based on the sample AMCap from the Microsoft DirectX 9 SDK. AMCap supports
still captures to BMP, JPEG and PNG formats and it remembers your Video Input,
Video Standard and Video size settings from previous session. It has some nice
features like multimonitoring support, zooming, aspect ratio and deinterlacing
features.
AMCap is a small and effictive piece of software and definitely worth trying.
Hope
this will help.Bud
This is the answer I gave to another user with the same problem I hope this helps....The Fang
Often when the computer goes into "sleep" mode, the camera may not re-initialize...you can restart and this will do the trick.
Also your keyboard may have a Fn key which is linked to the ESC key that which turns the camera on and off, if your computer has this key try it and see what you get good luck....The Fang
