I have not used this camcorder in a few months. I cannot get it to charge or turn on. When I plug the camcorder into the USB on the computer, the light flashes red about 10 times then stays solid red. When I hold down the power button on the camcorder, nothing happens (whether it is plugged into the computer or not).
SOURCE: HELP! I have a JVC Camcorder,power is flashing and its not charging!
This seems to be some sort of model problem as I have the same problem. I have bought two new batries and both of them are now in same state " simply they won't charge"!!! :(
SOURCE: Uploading Problem
You just need to finalize the disc- i had same problem and just tried it - and it worked straight away, hope it works for you
SOURCE: Nextar MA 166 MP3 Won't Charge
You have to install the software for the mp3 player BEFORE connecting the mp3 player to the computer, or else Windows XP will override the native drivers. That particular Nextar is not compatible with Windows Vista, so you may have a problem if you have a newer computer.
-Tha Mp3 Doctor
SOURCE: My camera won't turn on!
Check your memory card you need a sd card or mmc for this camera make sure your card is not an sd hc card over 2gb it will not support it
SOURCE: Jazz DV-179
YOU PEOPLE IT IS JUST THE BATTERY THAT IS IN IT!.. BECAUSE THAT BATTERY IS NOT ONLY FOR AFTER IT IS CHARGED IT ALSO WORKS TO SHOW THE DISPLAY SCREEN! BECAUSE IF YOU TAKE OUT THE BATTERY THE LIGHT STAYS ON WHILE ITS PLUGGED INTO THE COMPUTER! MY BF IS HAVING THE SAME PROBLEM TRY BUYING A NEW BATTERY!! ITS THE SOLUTION! the battery is caput!
