Water accumulating in bottom of whirlpool refrigerator with top freezer with ice maker. what is problem and fix?
Hi, check drain, in refrigerator section, your drain is blocked. open refrigerator door, look at back , inside ref. It's better to remove your produce, and shelves, for better access, check carefully, at the back of ref. above veggie drawers, check for drain and clean, if your drain is not blocked, possible condensation. Causes, hot food, high room temperature, (hot days) regular openings. whenever hot air gets inside of refrigerator, it's cool and condenses to water, check you door gasket, make sure ref. door (gasket) seal (closed) properly, first check ref drain inside of ref, sometimes they clogged up. also make visual check, to see if any water is coming from freezer. Good luck.
It's likely the condensate drain is plugged. You can access it from the back of the refrigerator. You can disconnect from the inside of the fridge and blow it out to ensure it is not blocked, then reconnect.
