The go back button usually works on cable remotes only, There are rarely universal remotes that the go back button works when programmed. Not saying there arent any though.
Start by turning on the device that you want to program.
(1) Press & release the device button that you want to program, lets say "VCR" LED will flase once
(2) Press & hold the "CODE SEARCH" button until the LED stays on.
(3) Press and release the POWER button. Point the remote at the device.
(4)The LED will flash as the remote is searching for the code.
(5) As soon as the device turns off press and release the "ENTER" button.
The remote should NOW be programed.
The instructions that came with my remote were COMPLETELY incorrect. I made note in pen in my jumbo remote manual. After hours of searching the web and piecing together various blogs, I wrote these easy-to-use instructions:
Place the jumbo remote and your old remote on a flat surface, head to head, with a 1" to 2" space in between (the remotes should be aiming at eachother).
Press and HOLD the device button on the jumbo remote (eg. TV) until the jumbo remote's small indicator light turns solid red.
Press the LEARN button once on the jumbo remote. The light will blink rapidly.
On the jumbo remote, press the button that you want to perform the learned action (eg. If you want the jumbo remote to turn your TV on and off, press the POWER button on the jumbo remote).
Press the same button on your old remote (eg. POWER button on my old tv remote control). When the jumbo remote's light changes from rapid flashing to slower flashing, press ENTER on the jumbo remote.
You're done! Try the jumbo remote out (eg. Aim the jumbo remote at your TV, press the jumbo remote's TV button, then press the jumbo remote's POWER button). Your television should turn on or off with your jumbo remote.
You can program any jumbo remote button this way (eg. MENU, EXIT, MUTE). Just make sure you press the same button on each remote in steps 4 and 5 (eg. MENU on jumbo remote, MENU or LIST on old remote).
This is the way to enter any device using the rmc10 really big universal control.
1. Turn the device one that you want to program. (The tv, dvd, vcr, etc.)
2. Press and hold the CODE SEARCH button until the red light remains lit.
3. Press and hold the device you want to find (example TV, VCR etc.) Release it quickly. It wil blink once.
4. Continuly press the CH+ button until the device turns off. This may take a lot of time and many clicks.
5. Once the device turns off, press the MUTE button. This stores the code.
6. Press the ON/OFF button and the device should come on.
There you have it! Save this information so you will have it next time.
The "auto" mode isn't quite presented correctly in the documentation or posts I've seen...after MUCH trial and error (and about 3 hous) I've been able to set-up ANY infrared device, either by "auto" or learn. (Although maybe not "fully".)
AUTO Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....llight will stay solid. 2. Now just press the [POWER] button (only) ONCE while pointing at the device...it will start sending codes approximately every second. (Don't keep pressing the power button as instructions indicate.) 3. TIMING IS EVERYTHING HERE. (It may take 5 minutes to find your devices code.) 4. AS SOON AS the power goes off...press the [ENTER] button on the JUNBO Remote. 5. Now pressing the [POWER] button should power up/down the device.
---- any buttons not programmed will have to be handled using the LEARN method ---
LEARN Method
1. Press & Hold (about 3 sec.) the [DEVICE] button on the JUMBO Remote....it'll stay solid. 2. Press the [LEARN] button on the JUMBO Remote. (light will immediately blink rapidly.) 3. Now Press the {NEEDED} button to program. (light will stay solid) 4. Now (1 to 2 inches away) have the ORIGINAL Remote pointed at the JUMBO Remote and press the {DESIRED} button on the ORIGINAL Remote. 5. It blinks rapidly while sending...then a slower steady blink once "LEARNED" correctly.
*** Not all buttons work properly with the "LEARN method". Some you will need to "associate" with an alternate button on the JUMBO Remote. ***
