My HP PSC 1315 prints the test page every time I switch it on. The only way to stop it is to press Cancel every time right after switching on the printer. It used to be fine and only print the test page on demand, but after the ink was changed it does it every time. I have a HP 1500 and I am having the same problem. I tried the solutions suggested by others without success. I am wondering if it's because I bought a compatible cartridge, i.e. not a genuine HP one.
Re: HP PSC 1513 all in one by Bert (9/25/07 1:07 PM) reply
Re: Re: HP PSC 1513 all in one test page always pr by Anonymous (12/12/07 6:14 AM) reply
Subject : How to disable the test page that always prints when you switch on the HP PSC 1513 all-in-one printer.
Take the test page ( also called : alighnment page ) that always prints when you switch on the printer and place it face down in the scanner.
Then press the scan button on the printer itself.
(this is the button at the bottom of all the buttons on the printer/scanner.)
Make sure that the printer scans the test page.
( sometimes you press the butoon and it doesn't scan )
( it makes a scanning noise when scanning succesfully )
Then it will stop printing the test page ( alignment page ) ever again.
This is a really stupid product feature on HP's part to waste ink and force people to buy more cartriges.
[email protected]
My hp psc 1400 prints the test page every time I switch it on. The only way to stop it is to press Cancel every time right after switching on the printer. It used to be fine and only print the test page on demand, but after the ink was changed it does it every time.
Http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00473766&lc=en&dlc=en&cc=us&lang=en&product=441122
HOPE IT HELPED CHEERS GUYS!!!!
Doing the scan made it work for me! It doesn't print a test page anymore. Thanks!
Yes it worked, Thanks for the link
http://h10025.www1.hp.com/ewfrf/wc/docum...
The Solution Provided from Hp PSC1513 is that the Printed alignment page (like test print page) face down on the scanner and press the "start Scan" button the printer scans and complets the alignment process. But In my case after that it again prints the alignment page... I think it is stupid feture, without asking to print the page every time and wasting lots of Ink.
I had this problem on few HP printers at last I have decided to thrash the HP printers and have changed the brands Lexmark and Samsung. This may not be a good solution how ever I have been happy ever after :)
I have a hp Photosmart 3183 it still dose the test page even after doing the scanning !! what to do ? when installing the driver i have a fatal error 1720 what to do ?
Joshua777 Has the answer to the HP printed alignment pages. It works and thank you.Even though the url takes us back to HP it is a pPity that HP does not have the brains to include this with the printers or cartridges they sell.
The simple answer to this as stated many times here before. I have a HP PSC 1500v. Mine was doing the same thing for a few weeks, then I went back to realize that when you set the computer to align(which you can find in the control panel under printers then find yours and click on properties, then tool box, then click on align)Then you print a test page, then place it face down in the scanner, then wait about 10 seconds, then press scan. When the power light has stopped flashing, you have completed the process, and you shouldn't have any more unwanted test pages.
I have a hp f380 but after doing the allignment process i still have it printing the test page every time i switch it on?
My HP1500 does the same thing - continues to print the alignment page every time it is turned on. I have tried removing and re-installing the print cartridge and even disconnecting/reconnecting the printer - nothing seems to help. It IS an HP print cartridge - someone mentioned the problem could be caused by an unathentic cartridge (that is not the case here).
My Hp1500 does the same thing with a Hp cartridge. I have tried unplugging it, re-installing the drivers and aligning print heads etc. nothing works.
has anyone found the solution? i also have this problem!!!!
thx
Yes, this is the solution. As it's about a month since I posted the problem, I had managed to work it out. Agree that it's a really stupid feature but I wonder if HP are listening???
I think this is not a solution but a further question. Unnisa must scroll up to the solution offered by tsedawa above.
the scanner.
I have a C3188 HP Photosmart all-in-one printer.when I replaced the B/W (genuine from Hp-no.850) I started getting the test prints every time I switched on the printer.
I have a C3180. Every time I install a new cartridge it prints the test page which uses a lot of ink. This printer eats ink (even with fast draft on) like a starving vampire as it is. How can I get the printer not to print this page? I haven't found an answer for this yet. Help!
The problem persists for me even after scanning...
i hate this problem.
I have the same problem with a hp 1410. I have done the alignment page thing but when i press scan all that happens is that it scans it to HP image zone rather than scanning it a an alignment page
My psc 1315 did the same after installing an HP cartridge. I followed the instructions that lizardza set forth and it worked perfectly afterward. Thanks for the answer to a long time trouble.
I have the same problem with my HP PSC 1500. Every time it turns on it tries to print that test page. Usually I don't have paper in the printer, but for all the times I did have paper in it.... Grr..... It's wasted all
my ink, and now I have none left for printing off resumes :(
So using
HP ink is supposed to work? I'll try that, once I get new ink, and if it persists I'll try scanning that page. I hope something will work, because it's just a waste of ink and paper! (ink especially, because it costs more!)
Thank you for your help!
We have a HP PSC 1510 which has always done this, even with HP cartridges installed. Am trying the scan method and hopefullly this will work.
The problem is not replacement cartridges (Hp1500L) as I have had the same one since new and still have the same problem, also I have the update patch installed so presumably no one is listening at HP, or if they are they don't know what to do.
Hi I had the same problem Hp Printer 1513.
We've all been so stupid not to simply follow the instructions, instead we've sat with the problem all this time! thanks to Lizardza's solution I did this and all is fine now.
I can't believe I also had this and didn't listen/follow the steps printed on this page! Thanks also to Fixya.
My HP 1315 is over a year old and it just now started printing the test page everytime I turn it on. I went to HP website and couldn't find any help. It's good old Google that helped me to find your website. I tried lizardza's solution and it helped. It is so simple... why does HP not state that on their website? Also I had a document that got stuck on the printing queue (spelling?) and HP printer trouble shooter has too many steps to solve the problem. All I did was turn off my computer and restart and voila, it was gone. Thanks, lizardza... thanks, FixYa... thanks, Google.
Yes I have the same problem and have tried everything but I cant try the scanner one becauese I dont have a scanner...what else can I do?
everytime I turn on my HP 1401 All In One printer it does a print a test page?
I have an HP C1380 that is also printing a test page everytime I turn it on. I have always used genuine HP cartridges. I scanned the test page, but it hasn't solved the problem. Any other ideas?
I have an HP PSC 1410 with the problem of printing a test page everytime I switch it on. I have tried all the suggested solutions but to no avail. I was wondering if anyone has come up with any new ideas
Baldynanny
after switching on hp 1410 All in one series printer, the on/resume light starts blinking indefinitely ever after inserting paper for print-out. Immediately message is flashed in monitor as align though the printer cartridges both color and black are intact. After clicking the align button, then testing page with color bar coders are printed wasting a page of print sheet. Even if closing the button -close then also the button indefinitely blinks and again the message Align is flashed for us to click the same button. Only after printing rubbish print-out, then normal document printing and copying is allowed. The problem was not in existence. But now, the problem is brought up to our notice. We don't know to restore the printer to the original status. Kindly reply.
I did all that stuff, and it stills print the darn test page!
My printer keeps printing the test page every time it's switched on hp
printer wants to print the same thing
it's same as my new hp2050 printer ,keep ask for alignment befor printing and print a test page withaout my command. i's frustating me .
