If water is leaking from the very bottom of the machine, your unit is broke and you need to call Cuisinart. If it is just overflowing the caraffe/basket:
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
I'm assuming
you've got a coffee filter pot as this is the
most common kind (especially as
wedding gifts).
1. Boil the water.
2. Put the filter (should come with the
pot) into the filter holder.
3. Add 2 level tbsp. of ground coffee
per 6 oz of water.
4. Pour some of the hot water over the
coffee grounds, giving them a few seconds to swell.
5. Now add the rest of the hot water and
allow the coffee to slowly drip through the filter.
6. Remove the filter with the coffee
grounds in just before the final drops of water go through.
7. Now sit down and enjoy!
