SOURCE: Error message at startup says..."Not enough space for music DB...must free up 6 MB of space.
your going to have to format your mp3 player.
SOURCE: Sansa e280r "not enough space for music db. please free 6mb."
RECOVERY MODE
Switch your Sansa E260 to its Recovery Mode:
1. Make sure the player is powered off
2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface
3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button.
4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode"
5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above)
6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6.
Next, Apply the firmware for the E260 (your player should be connected to your PC at this time):
Step 1:
Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop":
http://www.sandisk.com/Assets/File/Downl...
Step 2:
Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred which caused the player to keep resetting.
Step 3:
When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch
Step 4:
Power up your E260 and 90-99% of the time, it would boot up successfully. If not, try to repeat steps 1-4 again.
I hope this helps.
SOURCE: not enough space for music db Please free 30 MG
Had this same problem. You need to lock turn off the player. put it into the locked mode and hold down the middle button before plugging it in. Then back up and reformat.
Detailed instructions I found were here:
Frozen sansa clip
SOURCE: " Not enough space for music DB. Please free 8 MB." Huh??
wire it up to a windows pc, treat it like a harddisk, search through the folders for the mp3's you won't to get rid off,delete the files you want from it, like you would from a computer.then copy some mp3's
to it, unplug, finished.
formatting it might erase some of the software the player needs to run, so you better don't. enjoy your favorite music :-)
SOURCE: not enough space for music db.Please free 6 mb.But
There is a factory reset option in the menu somewhere. Use that, or you can format the disk in the settings menu as well.
