Jeremy Adkison Posted on Mar 04, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
4 digit codes for a kenwood kr v6040 - Kenwood Audio Players & Recorders
Tom Chichester
Level 3:
Top Expert:
  • Kenwood Master 62,329 Answers
  • Posted on Feb 01, 2021
Tom Chichester
Kenwood Master
Level 3:
Top Expert:
Answers
62329
Questions
0
Helped
672590
Points
975369
Applicable codes would be found in a compatible remote control.
5 Related Answers
Anonymous
  • 319 Answers
  • Posted on Aug 14, 2008
SOURCE: problem with playing my Kenwood KR-X1000
Unit apparently has problems. Check/replace batteries in remocom
Anonymous
  • 11896 Answers
  • Posted on Jun 01, 2009
SOURCE: need a code for universal cox cable remote to turn on and off Kenwood KR-V-8040 Receiver
[PDF] Cox Manual File Format: PDF/Adobe Acrobat - View as HTML
not respond to the Cox Universal Remote Control after trying all of the codes listed for your brand,or if your brand is not listed at all,try searching for ...
www.cox.com/support/digitalcable/hdtv/pdf/Universal_Remote.pdf - Similar pages
  1. More results from www.cox.com »
  2. Universal Remote Control Codes Apr 17, 2009 ... More Cox Remotes, Includes Cox Digital Interactive, Universal DVR, Navigator, Millennium and Model ER1 PDF manuals. Cox Universal Remote ...
    www.xdiv.com/remotes/ - 73k - Cached - Similar pages
  3. How to Program a Cox Universal Remote for Your TV | eHow.com How to Program a Cox Universal Remote for Your TV. Have you ever dreaded programming your universal cable remote for your TV? Many people put off this very ...
    www.ehow.com/how_2153479_program-cox-universal-remote-tv.html - 52k - Cached - Similar pages
Anonymous
  • 222 Answers
  • Posted on Jun 08, 2010
SOURCE: kenwood kr 3600 volume potentiometer is faulty
try google and it will give you some local electonic stores
Anonymous
  • 8546 Answers
  • Posted on May 18, 2011
SOURCE: kenwood kr-v888d after "ON", through 3sec.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
kenneth njonjo
  • 1575 Answers
  • Posted on Nov 24, 2011
SOURCE: Kenwood kr-720 service manual
Hi Vanpost941,
You can download the manual in pdf by clicking here. or here.
Hope this helps.Thanks!
Please rate this answer.
Kenwood KR-V8070 accept digital signals, trying to hook up to cable box?
The Kenwood KR-V8070 has no digital audio inputs; it only has analog inputs. You can see the manual's diagram of the rear input/outputs starting on page 4 at ManualsLib: https://www.manualslib.com/manual/287040/Kenwood-Kr-V8070.html?page=4#manual . If you need to connect a device that doesn't have an analog audio output, you will need an analog to digital audio converter. This is one version: https://www.amazon.com/SANOXY-Analog-Digital-Converter-Adapter/dp/B005F20756 . You will need to supply all of the audio cables separately.
The later KRF-V8070D does have coaxial and optical digital audio inputs. I hope this helps.
2answers
Can the Kenwood KR-4600 connect to an ipod?
Hi,yes you can connect Kenwood KR-4600 to an ipod.
Instruction..
You will need an coolken_9.jpgRCA cable .
Connect the RCA (red and black to the input of the Kenwood KR-4600...You have options of inputs to use..
Either input at the back of the Kenwood KR-4600,or tape A and tape B..which ever you wan to use..
After connecting the red and black RCA to Kenwood KR-4600, then connect the other jack end to the ipod, and go the front of the Kenwood KR-4600 to activate the input selection knob to the desired input being selected at the back of the Kenwood KR-4600..
And don't forget to turn on the volume of the Kenwood KR-4600 and also the iPod volume..
And after that your done..
Good luck to you..
How do I hook up my HD TV to the kenwood kr-v7080 so I can hear stereo TV ?
Maybe hook up the actual source of the TV audio (not necessarily the TV) directly to the Kenwood. Cable and SAT boxes have nice standard digital audio outputs. They're wasted on TV's which typically have sucko speakers. Lower-end analog audio is also available if you want to watch Cable/SAT throught the TV speakers.
I have a Kenwood KR - V6080 receiver. I need to look at a manual.
The manual is available at retrevo: http://www.retrevo.com/support/Kenwood-KR-V6080-Receivers-manual/id/479bh942/t/2/ . You will need to enter a code to download the PDF.
I hope this helps.
Need a code for universal cox cable remote to turn on and off Kenwood KR-V-8040 Receiver
Have a kenwood KR-V990D and can't seem to bring the volume up
kenwood has always showed negative numbers 00 is as high as it will go
2answers
Problem with playing my Kenwood KR-X1000
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Ngoro
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
