Where did you get a 380 volt motor? Is the motor rotation correct, Using a clamp on ammeter, measure current on all 3 legs with motor unloaded, let run for a while. Next measure current with pump loaded. this will tell you that the motor is not overloaded. If motor is not overloaded, you will need to checking control circuit.
SOURCE: installing an air pump in a 5000 litre tank
The pump must be mounted nearest the 5000 liter tank. The air intake will be the air sorrounding the area, while the discharge low pressure air must be pipe to underwater level such that the air discharge of the air pump bubble up the water (aerate the water) inside the tank. This is common in fish pond/ shrimps pond/ and water treatment plants. Electrical wiring is
standard for the electric motor and controls.
SOURCE: hi i looking for
Don't knw what your problem is but here is a page that gives you the information, normally 3 phase on single phase motor but if you can change the winding settings you might here is the page hope it helps.
http://www.pentairpool.com/pdfs/CSeriesCommercialBronzePumpOM.pdf
SOURCE: I am looking for an
If you visit their water site along the top you will see 'service' and 'sales'. Depending on what you need select one and follow the screen prompts for a local agent. Their site can be found at:
http://www.franklin-electric.com/americas-water-systems.aspx
John
SOURCE: Iam looking for someone to supply and install a
Are you talking about a priming pump on a diesel engine. Most shops will do it pretty cheap or if it just needs to replace an old one it would be an easy DYI.
