the brand name is SanDisk Sansa Fuze, but i have no idea what the model number is. i can't read itthe brand name is SanDisk Sansa Fuze, but i have no idea what the model number is. i can't read it
You can't post conmments that contain an email address.
Can you try holding the power switch for about 30 seconds? If that does not work, you could leave it for a day or two then plug it into a wall charger for about another dayCan you try holding the power switch for about 30 seconds? If that does not work, you could leave it for a day or two then plug it into a wall charger for about another day
Please make sure you have a loaded battery in it and that the positon of the hold button allows you to access all other buttons. If still not fixed, do wire it up to a PC using the USB cable and try to access it. File management/sychronization is working? what does the player's screen show now? is the sd-card accessable?
Unplug, remove and reinsert battery then. Try again to operate it. If still not lucky, try a firmware-update. Drivers are downloadable at
Just because you charged the battery it doesn't mean it is any good. Modern sealed batteries fail; just as you described, fine one moment and then nothing, they go open internally.
Flashing is either an error code or the set trying to boot up--some of the Mitsubishi sets if power removed will blink for a minute and then stop--then the set can be turned on.
Tv projection Lamp might be some how the causes again.Tries unplug,replug tv back like about an hour later.Try it again,should work now.If not,yes the projection lamp,might have been kill by the cold weather.
If you were charging it with your USB cord, you have to keep the computer turned on the whole time it's charging, otherwise, it will be losing it's charge.
I did the firmware upgrade and it is telling me that there are no upgrades avaiable. It was working finr last night then it shut off. I replaced the battery and all I am getting is Pearl on my screen.
I think it over charged. I left it on all day. When I returned home it was turned off. Before when I tried to turn it off it wouldn't. I turned it back on and it was fine, but the battery was very low. I charged it for a smaller amount of time. It is now fine and working like normal!
