Frigidaire CFEF372cs2 stove F1 & LOC APPEARS ON PANEL and it continues to beep. Can I use the top plates of my stove but first how can I stop the annoying beeping sound?
SOURCE: F1 error code, continual beeping all other oven functions work properly
Here are the error codes for Dacor:
DACOR
Range/Stove/Oven Fault Codes
Failure
Code
Condition
Check/Repair
F0
Clock pushbutton is stuck in a depressed position
Check clock buttons
F1
Element relay circuit failure
Control board may be bad
F2
Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only)
Call for service
F3
Short Circuit in the oven temperature sensor
Check oven temperature sensor for continuity, if no resistance (zero ohms), replace
F4
F6
Failure in the EEPROM check comparison (only time of day and timer will operate)
Call for service, electronic clock control is usually the cause of the problem
F7
Failure of the self- clean automatic door latch system
Check door latch and switch(es)
F8
Failure of the door latch motor. Occurs when the motor runs for two minutes without the door locking in self-clean mode
Check door lock motor and door latch
SOURCE: Stove reads "F1" on the display and beeps
Go to www.applianceaid.com/images/ge-built-in-oven-faultcodes
Disconnect the plug to oven and let set for 30 secs then re plug into receptical
SOURCE: Frigidaire Stove beeping F1,How do repair this?
The f1 code means that the EOC (Electronic Oven Control) failed. You need to replace the EOC board.
Good Luck And Please rate
SOURCE: My stove has started to beep random--why
WE used the broil button last night and our stove started beeping nonstop.It also say F1 three hrs of beeping we unpluged it for the night.When we turned it back on today same thing happened with the beeping and F1.hOW CAN WE FIX THIS?
