Hi there could you please advise me as trying to print flyer accurately on both sides of same page.
SOURCE: Epson C900 print shifted down page -
OK after messing about with the drivers I got it to work. I downloaded a driver from Epson singapore and it made no difference. So, I re used the driver from Epson UK and hey presto the thing works again. Why? Good question. Maybe the people in Epson have no idea either.
So, I suggest deleting the driver rebooting the system and reinstalling it. I hope you get it working.
SOURCE: HP Laserjet 1320 - Gray bars printing on sides of paper with dark dots
It sounds like a defective toner cartridge. Try replacing it. If that does not cure the problem, then the fuser assembly needs to be replaced, in which case it is probably cheaper to buy a new one.
Good luck
John
SOURCE: Canon MP730 won't print at all (blank pages).
try to move the blue nozzel over the printing head to the from the right to the left and try, it will work
SOURCE: Printer prints multiple pages with DPR1260 print server
I was having the same problem when I added a Windows Vista PC to my home network. My older XP systems workd fine, but the Vista system would keep printing. The following fix worked forme in vista, may work in XP also.
1. First, be sure you have the latest firmware in your DPR1260. Version 1.24 is what I am using.
2. From the printer window (or via controlm panel) select your printer, then select Properties (either right click, or from the menu via File-Properties)
3. In the Properties Window, select the Ports tab. You should see your printer highlighted and checked, under the port heading next to thcheck box you'll see IP_192.168.x.x, under descriptio Standard TCP/IP Port, and undr Printer, the name of your printer.
4. Click the "Configure Port" button, be sure "LPR" is selected, not "RAW". Under LPR Settings, check that the "Queue Name" matches that in our DPR1260 status screen, and be sure SNMP Status Enabled is not checked.
The problem on my Vista machine went away when I changed from "RAW" to "LPR" settings.
Hope this helps.
SOURCE: Epson SX 205 ink insn't low but is not printing yellow or green
Status monitor just show approximately, not real level. It might be yellow and cyan ink is out actually.Others, yellow and cyan nozzle may be clog. Check nozzle, do head cleaning. Check nozzle again.
