My 2001 Harley Davidson ultra classic I left the ign on battery died charged it back up now it will not start I have tried all kinds of codes but nothing is working it seems to be the security system
Start by pulling all fuses and reseating them.
If you’ve found this helpful, please click the green “helpful” icon. If you have 20 seconds please leave a few words as a review or recommendation! Also, follow me for more answers to everyday issues, I’m all for saving you money and making the most of your time! Thanks and have a great day!
SOURCE: removing harley davidson ultra classic gas tank
Drain the fuel either by siphening or removing the cross over tube at the front of the tank and letting it drain that way or just block off those cross over lines and leave the fule in the tank for removal.
0) remove seat
1) drain fuel
2) undo cross over line (bottom front of gas tank.
3) shut off pet **** and remove fuel line from pet ****.
4)there should only be 2 bolts holding the tank on, one at the top front of the tank and one at the back of the tank.
All in all a pretty easy (but possibloy messy) job.
SOURCE: 2002 harley davidson ultra classic setting the clock
Turn the Bike on and the Radio off and then follow the buttons on the screen. Most people think you have to do it while it is running and this does not work
SOURCE: having trouble changing a kick stand spring on my
well the easy way is to jack up bike remove the nut jiffy stand slide it out hook spring slide it back in and tight nut hope this helps
SOURCE: starter removal on 2004 ultra classic harley davidson
Disconnect battery , remove the outer primary case, pull back the lock tab on the starter jackshaft, unbolt the retainer screw, then remove the two starter bolts from the right side, sometimes you need to loosen the oil tank mounts to get at these, slip the starter and coupler out as a unit, replace the coupler and jackshaft the same way they came out when the new starter goes in, install bolts , retighten the jackshaft bolt and bend over the retainer, install and fill primary case, connect battery thats it buddy
SOURCE: My 2003 Harley Davidson Ultra Classic is cutting
I had a problem like that on my 2003 ultra classic. turns out there was a recall on some electric block in the fairing. It was a main connection power block kinda thing. Anyway they replaced it and then it never happened again.
it would ride a while on a hot day 25 min freeway and then just shut down. wait and cool down and it would restart.
I hope this helps.
JD
