Just clicks won't open unless you make them open but when eyes blink and or close they won't open again
How can I fix luvabella eyes they won’t open or close
Hello, Cliff -
Apparently the Luvabella dolls are manufactured and sold by Spin Master. This is the link to the Spin Master Contact Us page:
http://www.spinmaster.com/contact-us.php?userLoc=us
If you click or tap on the Customer Support "button", you can fill in a form which can be sent as an email. Or, if you click or tap on the Customer Service link, with the telephone receiver icon, you can find the Customer Care telephone number to call. Or, the Contact link, will display links for countries worldwide.
I did not see your problem described in the instructions for the Luvabella doll,
https://spinmastersupport.helpshift.com/a/luvabella/?p=web&s=getting-started&f=instructions&l=en
therefore, I think you need to contact Spin Master directly and ask about the problem you are experiencing.
Best wishes.
SOURCE: door will not close. led blinking 5 times
Is your door open or closed? If you release the door is it easy to open and close manually? Does the opener run with the door released?
SOURCE: Door won't close unless I hold the button all the way down.
make sure the eyes are clean and aligned if the opener thinks something is obstructing its path it will not close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
You might try removing the battery for a minute or two to reset the camera. You may lose any special settings in the process. After reinstalling the battery, try turning the power on and off again.
We had the same problem a few months ago. We even bought another dummy, but it did not help. Then we found the solution by ourselves. My daughter took her baby born to her bath and we put her into the water. Then I pressed ******* the face for water to go inside through the eyes many times. After I did it a few times with a lot of water the doll start to close and open her eyes again with her dummy. I do not know for what reason but eyes start to stick inside. I believe it may be because of the food, or dust. Maybe not. However from my observations it happen when we did not bathe her for a long time.
I hope it helps.
