I need to shorten the wash cycle time and sometimes like now just respin to shorten the drying time. I am ready to get rid of this machine I cant stand not being able to choose water level agitation level length of time for cycle
SOURCE: Kenmore Elite Model 110 washing machine will not stope the agitate cycle
If the washer fills but does not agitate or spin, this is usually a symptom of a bad lid switch. The switch will either be located on the right hand side of the washer tub opening, or in the rear on the left hand side under the console. If you have a right hand model, examine the lid and make sure the plunger that activates the switch when it is closed is still intact. The plunger is a plastic piece that is physically mounted on the lid. Sometimes they break off. If the plunger is intact, try taking a small object (like a screwdriver or popsicle stick and push down on the lid switch contact while the lid is open and the timer knob started. You should hear a distinctive "click" when you push on the switch and the washer will agitate. Sometimes the switch can become loose and no longer make good contact. If this is the case, simply tighten the two mounting screws on the tub opening. If the switch relay is not clicking you may need to replace it. The part runs about $35.
If you have the left hand style switch that is enclosed under the console, the contacts are closed by a small metal bar on the back of the lid. Sometimes this bar becomes bent or loose. Open and close the lid and listen for a distinctive "click". If you don't hear anything, you may need to adjust the metal bar, or replace the switch. This style of switch tends to cost a bit more.
If you can provide me with your model number (located under the wash lid along the tub opening), I can research the part number for you and let you know where you can get it and give you step-by-step instructions on how to replace it. This is a simple repair job that the average consumer can perform with simple instructions and a few household tools. First, determine if this is the cause of your problem. Post back with comments and let me know if this helps you.
SOURCE: kenmore elite HE4T front load washing machine standing water
This problem can be caused by either a leaking water inlet valve, or a condition known as "siphoning". Since you just recently moved, I would make sure you don't have a siphoning problem, first. The following link explains how:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Although siphoning normally refers to a constant drain problem where a washer has problems maintaining the proper water level, it can also lead to problems where the drain line will back up into the washer.
Now, if you follow the advice in the link and determine this is NOT caused by siphoning, I would suspect that you have a water inlet valve that is leaking. A tell-tale sign will be water trickling down the fill tube in the rubber door bellow. The water inlet valves have a diaphragm that is controlled by an electric solenoid. Sometimes the valve becomes clogged with sediment or deposits, causing the diaphragm not to close properly. If you live in an area that has hard water, or use well water, you may have hard water deposits or rust build up in the valve. You may be able to correct the problem by removing the valve and cleaning it with some distilled vinegar. You can remove the valve by following these steps:
1. Unplug the washer and turn off water supply at the taps.
2. Disconnect the water inlet hoses.
3. Remove washer top panel by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel slides back, then off.
4. The inlet valve (this is what your water inlet hoses connect to) will be located in the left rear of the washer (facing from the front). Remove the dispenser hose(s) from the valve and the electric connections. Remember how the electrical connections are removed. They should be color coded. One is for HOT, one is for COLD.
5. Remove the mounting screws that hold the assembly in place.
Once you have the inlet valve removed, you can place it in some distilled vinegar and let it soak. Just don't submerge the electrical connections. If this does not correct your problem, replace the valve. Searspartsdirect.com and repairclinic.com are two notable web sites that I have frequently used. Just type in your complete model number to begin the parts search.
I hope you find this information helpful. Let me know if you require additional assistance.
SOURCE: Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
SOURCE: Kenmore Elite Calypso washer won't fill with water!
Kenmore Elite Model 110.24082200 won't fill the tub completely with water on any cycle before washing begins. Nothing is wron with the water source. Why won't it fill?
SOURCE: Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
