Troy Bilt 4 cycle weed eater.
Engine spins fine. Weed eater attachment head doesn't spin. Pretty sure attachment isn't seating properly into drive shaft, but don't know how to make it do so.
runs great but after use it makes a squeaking sound until its completely stopped spinningruns great but after use it makes a squeaking sound until its completely stopped spinning
it is getting hot from friction because you cannot tighten it so the head spins but everytime it hits a wed it tries to stop spinniing because it is slipping from the bolt not tightened. fix the bolt hole with a tap and put in a new bolt
Your clutch has failed. Most common reason is a broken clutch spring, but sometimes a shoe will break. To get to your clutch, you need to separate the engine from the shaft at the front face of the engine, NOT where the shaft enters the engine housing.
sounds like your flex cable has taken a trip south. Pull the shaft off the head and take a look at the flex cable. If flex cable is ok, they your clutch is defective.
Sound like the clutch is going out or already is bad. There should be a cone shape cover that attaches the engine to the handle. Usually with 4 screws. Take those screws out and seperate the housing. There is a small centrifugal clutch, which is probably bad.
needs flexable drive shaft
