When using the weed eater or edger I use to be able to put pressure on the head (on the ground) and stop the spinning so I could check to see if I need to bump for more string or to stop the blade from spinning on the edger. Now if I do that the engine stalls. It's like the clutch isn't engaging (or dis engaging what ever the case may be).
SOURCE: troy built weed eater won't feed line
Check the size of the line,(OD), make sure you are using the correct size, sometimes cheap line will be problematic, also, you said you are re-stringing it, try a new batch of string, the old string inside the hub can get chaffed and will stick to itself...
SOURCE: Pull string for Weed Eater Featherlite Plus came out
If you have the starter spool out (the one the rope goes in)...Here is what to do. Take the starter spool and change the rope out putting it back exactly as it was. Leave the rope hanging. Hold the spool and set it down on the rewind spring. Turn the spool on the rewind spring until you feel it is tight enough. While turning, hold the rope in the little slot in the spool so it can go around without hanging up. Once it is tight, get the rope in line with the spool opening and SLOWLY let the rope rewind. Put on the handle and put the unit back together.Good luck...Lee
SOURCE: I need to replace the head on a troy bilt TB575 ES
at the end of the trimmer where the cutting head assembly connects to the gear box there are some screws. unscrew and replace with the universal head.
SOURCE: The head will not spin on Troy Built weed eatter
sounds like your flex cable has taken a trip south. Pull the shaft off the head and take a look at the flex cable. If flex cable is ok, they your clutch is defective.
SOURCE: i need to know what
Hi jo6616...
Use a good grade of 10W30 non-detergent oil in your weedeater.
Free answer....Please take time to rate me
