Question about Troy Bilt Tb70ss Gas Trimmer
Troy built weed eater won't feed line
Troy Built weed eater will not feed the line. Have to stop and re-string often. Very annoying.
Posted by wheelerplumb on
Anonymous
  • 65 Answers
Check the size of the line,(OD), make sure you are using the correct size, sometimes cheap line will be problematic, also, you said you are re-stringing it, try a new batch of string, the old string inside the hub can get chaffed and will stick to itself...
Posted on Aug 22, 2009
Why does the weed eater not trim even though it spins?
it is getting hot from friction because you cannot tighten it so the head spins but everytime it hits a wed it tries to stop spinniing because it is slipping from the bolt not tightened. fix the bolt hole with a tap and put in a new bolt
Jul 14, 2015 | Troy-Bilt Troy-Built Gas String Trimmer...
Troy bilt weed eater
I have a troy built 2 cycle pro-line tb90bc spring assist trimer.
its getting fuel and it wouldn't start I took out the spark plug and it was wet with fuel. pls fwd any info to [email protected]
May 06, 2013 | Troy-Bilt Tb90bc 17-inch 31cc 2-cycle Gas...
Replace duel string trimmer line
Change the line on Troy Bilt 4cycle TB525EC weed eater
Oct 16, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
The head will not spin on Troy Built weed eatter
sounds like your flex cable has taken a trip south. Pull the shaft off the head and take a look at the flex cable. If flex cable is ok, they your clutch is defective.
May 29, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I don't know how to load line into the Troy Bilt Speedlock head
cut to pieces of string about 8 ft long. run your line through the holes on the side of the head. you will see 2 smaller holes on the inside. put the string in those 2 holes and begin turning your head to install the string.
Aug 22, 2009 | Troy Bilt Tb70ss Gas Trimmer
Tryingto replace my troy built weed eater's head
Replacement head can be purchased from amazon, here Amazon com troy built head. I hope this helped you. Have a nice day. Vince
Jul 12, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Poulan Weed Eater Trim Line Constantly Jams
Sounds as if the line is wound on the spool the wrong way, causing it to want to always feed string.
Jim
Jun 13, 2009 | Poulan Garden
My Troy Built weed eater wont keep string going.
troy built is pure trash ill never waste money on any of thier trash agin i have a weed eater 5 months old it wont even crank pure china trash
May 09, 2009 | Troy Bilt Tb70ss Gas Trimmer
Black and decker grass hog electric weed eater won't feed string
I bought the electric grasshog trimmer. Worst investment I ever made on Garden supplies. The line is completely gong within ten feet of trimming. I've used it four times and gone through twenty spools. In the trash now.
Apr 22, 2009 | Black & Decker 14" Grass Hog Xp...
Troy Bilt Tb70ss Gas Trimmer Logo
1,181 people viewed this question
Top Troy Garden Experts
colesmowers
Brian Anderson
Dennis Key
Dennis Key
Are you a Troy Garden Expert? Answer questions, earn points and help others
