Home Logo
B
Bonnie Wilson Posted on Jan 24, 2018
Back jets wont work on princess maax tub - Maax Home
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Jun 16, 2009
SOURCE: Two jets stopped working
Most of these jets turn to close. Check if you turn the nozzle. Hope it helps
Alan
  • 80 Answers
  • Posted on Aug 19, 2009
SOURCE: Cold air blowing into Maax Velvet 6032 Bubble Tub
The air coming from the blower will be cool, but should not be cold. Turn on the blower or bubbler feature (no water necessary) and go to the access panel ( as specified by install instructions), reach in and feel the tube connected to the blower, the tube should be warm, if not the heater coil is not working and the blower assembly needs to be replaced.
Alan
  • 80 Answers
SOURCE: E06 on newly installed maax calla
E06 is the water sensor, The tub will not operater if there is not enough water in it. If the water level is not the problem, it is most likely a bad water level sensor.
Anonymous
  • 10865 Answers
  • Posted on Sep 01, 2009
SOURCE: Maax bathtub Palace model Error code C01 jets don't turn on.
first of all check the circuit breakers to be sure one or both aren't kicked. be sure to turn the breaker all the way off and then fully on as a tripped breaker is in a halfway off position. if that doesnt fix your problem remove the access panel to the mechanical space in your tub. there are generally one or two reset buttons in there which can also kick off and need to be reset.
Anonymous
  • 123 Answers
  • Posted on Sep 08, 2009
SOURCE: Hi, We purchased a Maax 10 jet Whirlpool tub
http://www.maax.com/Upload/guides/fr/000_10050073_0305.pdf.......this should take care of what you need. If you have any questions just ask.
Thx
Ken
My 10 jet tub not working maax brand from home depot
These units sometimes have a GFI outlet behind inside wall under the tub some where or in a closet or even in the bathroom some where-check if you do have one it may need to be reset
Sep 06, 2017 • Maax Home
Hello, I don't have a problem, but more of a 'change' in mind. I have a maax whirlpool tub but really miss soaking in a tub with bubbles, or oils, or oatmeal treatments, etc. I feel I cannot do this...
your friend is correct. Actually the oils will not hurt the system either but not sure about Oatmeal in the tub. As long as the jets were not turned on with the Oatmeal thingy going you would be just fine.
Jan 13, 2011 • Maax Home
Need replacement parts for a MAAX WESTCO INC A159869 8Z31 Jet Bath Tub Would like to replace the white plastic parts in side the tub with chrome as they have turned yellow
Try Guillens.com or usparts.com I have had some good luck finnding jets. Maax is still in business and you might be able to get the jet directly from them, although they are in Canada. Hope this helps.
Aug 11, 2010 • Home
1helpful
My bathtub jacuzzi wont work. I reset the circuit breakers but nothing. I filled the tub but nothing comes out of the jets
make sure you have power to outlet that motor is plugged into,if so try pushing jet button in tub about ten times in a row quickly then on tenth push use as much force as possible and hold.if this does not work,air hose from back of button to pump motor may be disconnected.
Thx
Ken
Aug 12, 2009 • Home
Cold water and jets don't work
Likely your mixer valve cartridge has a blown o-ring.
Replace the cartridge.
Jets not working may be as simple as the GFI outlet being tripped.
Thanks
Top Maax Home Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Maax Home Expert? Answer questions, earn points and help others
