SOURCE: Remove exixting fan
Should have screws close to the ceiling on cover, then if it's a ball and socket you lift up and out through the cutout on the socket bracket, or a flushmount you find the screw that attaches to the bracket and lower down. then just take off wire nuts and install new fixture. Hope this helps.
SOURCE: How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
SOURCE: Casablanca Ceiling Fan
I've never heard of the light and reverse buttons being reversed. Normally It's the fan and light thats swapped (but your aware of that already). I would try a working w-32 from one of the other fans. There's also a shop called Fan Man Lighting in Minnesota who has a guy named Jason who has been fixing fans for over 20 years, He helped me with my Casa problems. Their website is www.FanManLighting.com Hope this helps.
SOURCE: Unable to reverse Thomasville ceiling fan rotation w/remote
I e-mailed Thomasville Lighting after my original post but did not get a reply. I then searched and found a similar problem on this site (http://www.fixya.com/support/t187540-ceiling_fan_not_reverse_remote) and read the Best Solution which mentioned running the fan at medium speed (not low), then pressing the Reverse Direction button....it worked. As stated in the original suggestion, this was very counterintuitive and not documented in the manual.
Signs of a bad capacitor in a ceiling fan include:
