Talk about the pros and cons of Natural Stone Flooring.
SOURCE: pros & cons
Though the CLK may not carve up the turns,it does a decent job, but I felt it excelled in driving comfort over NJ **** roads. I do a lot of highway driving and prefer comfort plus I get up to 27mpg going nicley above 65mph.
SOURCE: Pros and Cons
Sansa e200 is increasingly not supported by the manufacturer, it may require you to manually switch between USB modes, and generally has a lot of problems. I can't think of any pros, actually.
The iPod has great support from the manufacturer and rarely has a problem that can't be solved. It is hard to use an iPod on Windows Media Player, but definitely not impossible. The probelm arises when you try to sync with Windows Media Player AND use iTunes.
I would definitely go with the iPod. Sansa sucks.
-Tha Mp3 Doctor
SOURCE: Thinking of buy an 2004 FXST? Pros and cons ????
Mostly the ride ... the softails are a little harsher than the dynas,,, i would try a dyna and see if you like the smother ride - as far as performance..... an 04 of either model should be pleasing
SOURCE: Pool and Spa Heaters pros and cons
Firstly,
the water volume in a pool is huge, so heating them need big amount of energy:
fuels or electric, which is up to the kind of water heaters the pool owner use.
Secondly, the water temperature requirement is not high:less than 30 C degree
will be OK. In other words, the terminal temperature of heat pumps (if used for
pools) will not be too high. These two reasons bring the application of heat pumps for
swimming pools.
In fact, you will say "what an ideal product designed for pools" when you know
the performance of this kind of products. The COP of swimming pool heat pumps
reaches 5, which means 1 electric can bring 5 heating energy. The number of
traditional water heaters (broilers or electric water heaters) will not be more
than 1. Nowadays, swimming pool heat pumps are popular in many Europe countries.
People install them for pools of their houses. Of coures, more and more pools in
gym are also heated by heat pumps. Even in aquaculture farms, heat pumps are
installed for fishes, for they need stable and warm water to grow quickly.
SOURCE: Pros and cons of gap year
From Brightside with some personal edits...
Advantages
Disadvantages
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steven_7f54ab9063554f66
Cork flooring has many advantages. Cork flooring is comfortable and easy to walk on, the cellular structure of cork makes the floor very durable which can absorb sounds and blows making the cork floor a great pick for apartments and condominiums.
