20 Most Recent liftmaster Garage Door 1/2 Hp Questions & Answers
If you want a professional Garage Door Repair service then, I would like to suggest you always prefer online professional service. Because they provide the best service at an affordable cost and also have experienced workers to fix all types of issues regarding garage door.
liftmaster... | Answered on Jul 11, 2018
Depending on the model the travel needs to adjusted, some models have a force adjustment. Call LF customer service the will help you.
liftmaster... | Answered on Jan 09, 2018
If these problems started immediately after a lightning storm, the printed circuit board is probably damaged. Contact a garage door service company (check the phonebook) for diagnostic support.
liftmaster... | Answered on Dec 02, 2017
The belt may have stretched. There should be an adjustment to compensate for stretching.
liftmaster... | Answered on Aug 12, 2017
Check the light sockets on either side of the garage door opener and make sure there is no corrosion on the contacts. If you see some corrosion unplug the garage door opener and scrape off the contact. Give that a try and lets see what happens.
liftmaster... | Answered on Aug 02, 2017
Thayst a logic board #.. What model # is the operater.. 8165 8500 8550 etc??
liftmaster... | Answered on Oct 02, 2016
first, hold the wall button down and do not let up and the door will close for you. second, one of the wires to your sensors is loose, broken or shorted out by a staple thru the insulation. you can bypass the sensors on a temporary basis while you find the issue, by jumping the sensor connections at the motor.
liftmaster... | Answered on Aug 13, 2015
internal drive gears are going. take cover off and take a look
liftmaster... | Answered on Aug 10, 2015
It could be the garage door motor that is acting up. Try closing it with the button in the garage. If that's not the case, you may need a different garage door opener.
liftmaster... | Answered on Jul 10, 2015
Sounds like the opener has opened to far and the trolley is now jammed against the stop bolt.
liftmaster... | Answered on May 26, 2015
all it is is the motor that needs replacing save urself some money and check inside for the model number of the motor and order a new one for around 50 dollars beleive it or not there are probably 20 to 30 things that use the same motor
liftmaster... | Answered on May 19, 2015
The opener is closing too far. On the side of the opener, you should see 2 white knobs, recessed into the side. Using a flat blade screw driver, adjust the close knob (closest to the door side of the opener), anti-clockwise until the door will close gently on the floor.
liftmaster... | Answered on May 12, 2015
Three blinking lights & door won't close by Candi
(Winston-Salem, NC)
Garage door will not open and close with remotes. Three blinking lights occur when we try to close door. What does this mean? It is a Linear unit.
I will assume you mean that your garage door will open with your remote but will not close. It should close if you press and hold the wall control button until the door is fully closed.
If that is the case, the 3 blinking lights indicate that your garage door's infrared safety beams are not properly aligned.
1) Check that the operator has power. The green lights on the sender and receiver should be lit.
2) If the receiver's green light is on, but the red light is off, the receiver has power but is not detecting the infrared beam from the sender. The red light might flash when the beam is partially detected. This can be caused by
mis-alignment or something blocking the beam.
Adjust the safety beam sender and receiver while watching the receiver's red light (stay out of the beam while aligning it). When the red light stays on, the beam is aligned and your garage door should operate normally.
http://www.linearcorp.com/pdf/manuals/LCO75.pdf
NOTE: If the receiver's red light remains off, check for:
1) Dirt on the receiver's lens,
2) Sunlight shining into the receiver's lens,
3) A short in the safety beam wiring (from staples or at the operator terminals).
liftmaster... | Answered on Feb 18, 2015
Make shure that the green and amber lights on the sensors are solid and not flickering ! most of the time when a sensor is not aimed exactly at the other sensor it will give a weak signal and not allow the door to come down , we call this a constant hold down since you have to physically stand and hold the wall button down for the door to go down , Your sensors are made up of a receiver and a sender , The sender always will be lit but the receiver may not receive a strong signal since it,s beam may not be pointing at the sender ...check to see if that's the case, also look for cob webs around the sensors since that can also trigger this , another thing that people always do is put brooms and shovels near the sensors and wind up getting a bad signal because a shovel is in the way of the beam , Check these things and you should have success in fixing your problem ! Hope this helps Sincerely Glenn
liftmaster... | Answered on Feb 07, 2015
Gear kits can be purchased for chain drive machines from any of these 3 brand names ...Liftmaster/sears craftsman /chamberlain / All 3 of these brand names are manufactured by Liftmaster the worlds largest maker of garage door openers and related parts ! You can purchase a gear kit on ebay for around $30 or less depending on the seller ! If you go to garage door parts sites it will be slightly higher so your best bet is EBAY , The gear kit only requires the main gear and sprocket housing that attaches with 3 screws , just remember after the gear is installed that you run the motor co that the trolley starts in the door down position otherwise you risk having the trolley smack into the opener , this is crucial for any travel adjustments that are made later! Hope this helps you ,sincerely Glenn
It definitely sounds like a sensor problem. In normal operation, one sensor will have an amber or yellow light on, indicating power to the sensing circuit. The opposite sensor should have a green light on. If the yellow light is not on there is no power to the circuit due to a broken wire or circuit board failure. If the green light is not on or is flickering, the sensors are not aimed at each other or the light path is blocked.
liftmaster... | Answered on Jan 20, 2015
liftmaster Garage Door 1/2 Hp Logo
179 questions posted
Top liftmaster Building Materials Experts
Terry Smith
Level 1 Expert
David Payne
David Payne
Glenn Mayer
Glenn Mayer
Are you a liftmaster Building Material Expert? Answer questions, earn points and help others
View Most Popular
  • liftmaster Building Materials
Most Popular Question
when open garage door no lights come
  • Building Materials
