Measuring Tools & Sensors Logo
C
CHARLES WILLIAMSON Posted on Nov 21, 2017
Packaging removal from Stanley fat max box cutter #10-778?
1 Related Answer
Anonymous
  • 12 Answers
  • Posted on Aug 04, 2012
SOURCE: How do i change the blade on the stanley box
Push the blade out as far as it will go and hold in the button on the side while slideing blade in and out.
How do you change the blade in a Stanley fat max knife 789
Don't touch the blade by hand use a pair of pliers. There should be a screw in the center of the handle, just remove it and you will see how to remove the blade.https://youtu.be/pFnbiw88Z8c
1helpful
How do I remove the original packaging from the fatmax
I agree. The packaging is ridiculous.
I removed it by grasping the packaging and pulling (very hard) from the blade end (bottom left as looking at it) straight out. This stretched and tore the plastic "paper" and pull the knife free.
Where do I buy a Stanley RL250 Fat Max Laser Level battery charger
I know it's 3 years old this question but I had the same problem. Good thing is the makita battery willl fit. I just got one from ebay works great
1500mAh 7.2V BATTERY FOR MAKITA 7000 7002 7033 192695-4 632002-4 Cordless Drill
How do i change the blade on the stanley box cutter fat max?
Cant put the thing back together after putting in new blade !!!fat max knife
some stanley knifes require stanley blades only, or make sure the clip blade is in is seated in the grove completely.
1helpful
Fat max laser is in inches need feet
Press and hold the "+ - units" button and hold for over one second. It should then let you select your units of measure. In this case it should be the second selection, which is "0.00 ft". If you lost your owners manual, you can download one at www.engineersupply.com/Manual-and-Help-Docs/Stanley-TLM100-Manuals.pdf. If you find this helpful, please rank the solution.
Top Stanley Measuring Tools & Sensors Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
ADMIN Eric
ADMIN Eric
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
