Question about Stanley Proto STANLEY IntelliDual Box Beam Laser Level
Where do I buy a Stanley RL250 Fat Max Laser Level battery charger
I am needing to purchase a battery charger for the above.
Daniel Harrison
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
I know it's 3 years old this question but I had the same problem. Good thing is the makita battery willl fit. I just got one from ebay works great
1500mAh 7.2V BATTERY FOR MAKITA 7000 7002 7033 192695-4 632002-4 Cordless Drill
Posted on Mar 12, 2016
How To plug in the battery charger,where on the mower is the connection to plug in the charger?
Hi Guys, There is not normally a plug in for a external battery charger. You take the charger unit as purchased from the supplier and do as follows; 1. Check that the voltage of the charger is the same as the battery to be connected. 2. Check there is water above the plates in the battery. Screw the plug out and shine a torch in to see. WARNING! Never strike a match or have a very hot bulb as the hydrogen from charging can explode!! 3. Connect the Red cable from the charger direct to the + Positive [Red] terminal being careful not to touch any other metal parts as this can cause a short and do much damage. 4. Connect the black [some times blue] cable to the Negative - end of the battery. Still being very careful not to short to the battery cage or machine chassis. Turn the power on and check that the lights are working or that the amp meter is showing a positive charge. Normally a flat battery will need at least over night and often 24 hrs trickle charge.
Aug 27, 2014 | Garden
Can i use it witout battery charger
Hello sai,
Of course you can use your camera without the battery charger but when the batteries empty then you will need to purchase batteries which is a lot waste of money. When purchasing rechargeable batteries the charger comes free.
Dec 27, 2011 | Olympus T100 Digital Camera
My laptop compaq cq40 is not charging, i think there is a problem on the charger
I would recommend taking it to a battery retail store or laptop specialists to have the charger and battery tested. It can be very expensive to purchase either a battery or a charger or both if not needed. Have it tested to verify the problem device ....then purchase as needed.
May 27, 2011 | Compaq Presario CQ40 Series Laptop Charger...
My 95 corolla will not start. When I put the charger on the battery it says the battery is fully chared. When I put the charger on quick start the starter clicks and grinds but doesn't pull in to turn the...
OK, if the battery has 12.5 volts or so, the charger will say it's fully charged. But, the real test is to load test it and check for CCA which should be like 550 CCA and above for most cars.
You could purchase a new battery from Walmart, an auto parts store, or Sears, and before you purchase it, have them test the old one to see if it is bad or good.
Once, you have a known good battery, then you can try it in the car. If it just clicks and grinds but doesn't turn the engine over, then you know you have a bad starter in the car, which will have to be changed.
Aug 17, 2010 | Toyota Corolla Cars & Trucks
Vivitar universal battery charger
http://shop.ebay.com/?_from=R40&_trksid=m570&_nkw=vivitar+universal+battery+charger&_sacat=See-All-Categories
If wanted to purchase a vivitar universal battery charger, you can check above link with ebay. Hope this helps you.
Thank you.
Aug 10, 2010 | Cameras
Our 743 came with a photo docking station that would recharge batteres. Is there another way to charge them
Yes you can., You can need to purchase a wall charger for you r NI-Mh battery the model number of charger is kodak K620 for or if you want a travel charger the model number is kodak K640., Or if your battery is special battery of Ni-MH (KAA2HR) make sure that you will purchased kodak K4500 charger., KAA2HR battery will not charge using a regular wall charger., Check first your battery before purchasing the charger
Nov 16, 2009 | Kodak EasyShare C743 Digital Camera
Battery and mains charger needed
To purchase battery,
http://www.gmkbatteries.co.uk/Cordless_Phone_Battery/BT/SYNERGY%202110/x/4/3/true.html
I can also check a place to purchase mains's charger.
But,
Check the price.If you purchase charger and battery, the price would be more than the price for the new phone.
Check the price - Only 9.9 B.Pounds.....
http://www.inest.co.uk/products/BT_Synergy_2110_DECT_Cordless_Phone.asp
I Hope i might have helped you to take a decision.
Thanks for using Fixya.
May 11, 2009 | British Telecom Synergy 2110 Cordless...
Need manual and patch cords. Can I get them
https://emporium.olympus.com/innards/emp.asp?val100=100&step1=909&step2=0
Here is the link to the Olympus store where you can purchase a battery charger and patch cables.
http://olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=909
Above is the link to the Olympus website where you can download a copy of the user manual for the camera.
Apr 16, 2009 | Olympus Camedia C-740 Ultra Zoom Digital...
I need to charge my battery and I'm not sure what to do. I have purchased a small charger.
all you have to do is clamp the red clamp to the red wire battery post and the black to black. Then plug in the charger.
Apr 15, 2009 | 1995 Suzuki VS 800 Intruder
I need a battery for a Polaroid t737 digital camera
To purchase accessories for digital and digital video camera model numbers beginning with: a, i, Ion, izone, m, t, CAA-04030S, Studio 4, x530, PDC (except PhotoMAX PDC models listed above) and Polaroid Pixie cameras, contact the number listed below-- Polaroid Digital Camera Support
USA / Canada: 1- 877 - 388 - 3779
Hours (EST): Mon-Fri 10am - 7pm, Sat 10am-4pm
Available accessories include -- batteries, USB and video cables, image editing software and other items that were included when you purchased your camera. Note: Accessories may not be available for some older camera models.
Dec 30, 2008 | Polaroid T737 Digital Camera
Stanley Proto STANLEY IntelliDual Box Beam Laser Level Logo
855 people viewed this question
Top Stanley Proto Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Stanley Proto Measuring Tool and Sensor Expert? Answer questions, earn points and help others
