Question about Stanley Fatmax Xtreme Retractable Utility Knife
Cant put the thing back together after putting in new blade !!!fat max knife
Posted by tony591 on
mlposey
    New Friend:
  • 59 Answers
Some stanley knifes require stanley blades only, or make sure the clip blade is in is seated in the grove completely.
Posted on Dec 23, 2010
How do you change the blade in a Stanley fat max knife 789
Don't touch the blade by hand use a pair of pliers. There should be a screw in the center of the handle, just remove it and you will see how to remove the blade.https://youtu.be/pFnbiw88Z8c
Oct 18, 2015 | Stanley Measuring Tools & Sensors
I have table saw (r4510)it has a spliter mounted on the side next to the saw blade hold question how do I get the spliter out of the holed out?
I assume you are talking about the riving knife behind the blade.
when you take the hole cover off the saw table, you'll see a lever down on the side of the riving knife that can be either straight up or you can pivot it down toward the blade. When its up, its for through cuts, the riving knife sticks up higher than the blade. <b>When you turn the lever down toward the blade, the riving knife drops down a bit so you can make kerfs that don't go all the way through the wood.</b>
When you take the blade out, you can also take the riving knife out if you are going to put a dado cutter in, but <b>don't remove the riving knife</b> otherwise.
Wood has all kinds of internal stresses that are relieved when you cut the wood. Often the slot the blade cuts results in the two sides of the wood curving together and pinching the blade. This if very dangerous because the back of the blade can get pinched and through your wood at you faster than a major league pitcher can throw a fast ball. I still have a bruise on my chest from this happening to me before thanksgiving. Good thing it was the whole end of a 2x4 and the wood didn't split into a sharp spear as the blade grabbed it. Don't take out the riving knife unless you are using a dado blade and then put it back in right afterwards.
If you don't have one, here's the manual for your saw:
http://tinyurl.com/npkv29o
Oct 06, 2014 | Saws
Centering saw blade
The most important thing is that the blade and riving knife are centered with each other. If not, you may have to shim the riving knife.
The bolts that hold the carriage under the table are intentionally sloppy so that you can loosen them and align the blade/knife with the miter gauge slots.
Lay a long metal straight edge against the side of a carbide blade teeth with the blade all the way up, and make sure the straight edge is parallel with the miter gauge slots in the table. Then tighten the bolts on the underside.
Sep 07, 2014 | Craftsman Contractor Series 10" Table Saw...
How does an electric knife work?
The way the knife works is that it has two knife blades put together. These blades are serrated (notched). When the power is on, the blades move sideways and basically saw through whatever they are cutting.
Jan 14, 2013 | Home
Have a Stanley Fat MAx utility knife and unable to open it to load the blade
there is a little black button on the end where the blade comes out. With the blade in the out position,push in the button and pull out the blade. With button pushed insert new blade or turn the old one around to use the other end.let go of the button and you are ready to go.
Jun 26, 2011 | Stanley Utility Knife
I have a stanley FatMax. How do I insert the blade into the case?
On the side there is a big gold wheel, twist counter clockwise and the case should split in half, the blade is held by a magnet, prise the old blade off and replace with new one, then put case back together and tighten gold wheel clockwise
Mar 06, 2011 | Stanley Fatmax Xtreme Retractable Utility...
How do you put blades in stanley fat max extreme razor knife
Not sure exactly because I don't own one, but the review seems to indicate you push the blade positioner all the way forward, and push a release to remove the old one out the front, and then push a new own in until it clicks in place. With the blade positioner all the way forward.
But the review said it did not work well.
http://www.crunchgear.com/2008/12/05/review-stanley-fatmax-utility-knives/
Feb 26, 2011 | Stanley Garden
I can't open or refill the fat max. Lost the instructions.
If it is a 10-816 then Knife swivels open for easy blade change and clean out - no tools required, much like 10-999
If it is a 10-778, you don't really open it. You press little button on left side, behind the blade wiper, and this releases blade. Push red button on rear of knife, to open blade storage
if it is a 10-999 then press the button on rear and rotate the two halves.
Oct 29, 2010 | Stanley Fatmax Xtreme Retractable Utility...
I unscrewed Stanley 10-379 Interlock retractable knife and now I don't know how to put back the gizmo that fell out or the three blades that came with it.
Google: how to change blade in Stanley 10-379 utility knife. Stanley website shows how knife & blade look on the outside. Put it together so it looks like that. Sorry, but ain't don't know how to send the picture to you.
Oct 21, 2010 | Garden
Stanley Fatmax Xtreme Retractable Utility Knife Logo
743 people viewed this question
Top Stanley Measuring Tools & Sensors Experts
Frank Walton
Level 1 Expert
Vernon Taylor
Marvin
Marvin
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
