Hi kimberly.
not sure if this link will help you out but have a look.
How to use the dough blade with my kitchenaid food processor Google Search
SOURCE: stuck dough blade
On the DLC 7 Pro cuisinart the blade was removed by removing
the plastic bottom. Make sure the unit is unplugged. Remove the four rubber pads on the bottom. This was the hardest part because the pads are glued so securely that the inner rubber surface tears as it's removed. I used two flat blade screwdrivers and worked carefully, back and forth. Using a #2 philips, remove the four screws. Place the unit on its side and while inserting a screwdriver between a spoke and the motor frame gently turn the blade counter clockwise. Be careful not to put pressure against the cooling fins. Very little pressure was needed and the blade came right out. I might have been able to hold the shaft from turning without removing the bottom, by going through the vent slots in the bottom, but I was concerned with cracking the plastic. To replace the rubber pads I matched the design of the torn rubber pad with the shape (design) of the surface glued rubber and used thin two-sided tape.
SOURCE: My 12 cup kitchen aid food processor dough blade
Dough is normally water soluble. Try soaking it in water for a several days up to a week. Then try prying it loose.
SOURCE: Need owners manual for kitchenaid food processor model # KFP740CR
http://www.kitchenaid.com/flash.cmd?/#/page/home
this site should help you out.
one thing, you can chop onions without crying.
SOURCE: attachment stuck on shaft of food processor
put the mixing bowl up as much as possible. spray some wd40 into the groove between the attachement and the motor shaft. Wait for several minutes, then with a hammer and a piece of wood, give the bowl a good wack. With a few goes, it will gradually come off. I will be putting some butter inside the attachement from now on to keep it lubricated
SOURCE: My kitchenaid food processor won't work
Does the actuator push down far enough to catch the button at the bottom? I repaired one simply by adding a vinyl screw cover to the top of the button so it was tall enough to be reached by the actuator.
Testimonial: "really helpful thanks"
My food processor is one of my most-used appliances. I just got a new Cuisinart (at Costco - with an extra workbowl!) and use it at least twice a week. I grate cheeses like cheddar or swiss, pulverize parmesan, make bread crumbs, hummus, pesto, salsa... I make pasta dough in it before rolling out in my Kitchenaid pasta attachment. Pie crusts come together in a flash. And it's great during the holidays for chopping nuts and certain cookie doughs. I've chopped my own beef for burgers, etc, etc. I keep it in a cabinet but it's easy to pull out whenever I need it. And there are only 2 of us at home.
By the way, the blades are so sharp in the new machine that I cut my finger trying to clear something from the blade. I'll use a spatula next time!
ford performance chips.
